Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 01-11-2006, 04:19 AM   #1 (permalink)
verdejor's Avatar
Date registered: Aug 2005
Vehicle: 1976 W116, 450SE --- 1981 W126, 380 SEL
ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM
1981 380SEL Euro, 8cyl
I had to set my car to 5degrees Before TDC (per manual), I can't get it to adjust to that, I can only get it to go to 3.5-4 BTDC, Distributor won't turn any more,
RPM adjusted to spec using idle air control screw (500RPM, tried 650)
I tried playing a little with the fuel mixture screw (car turns on fine, it still has some black smoke when accelerated)
any clarification on how to used the pins on the computer diagnosing circle by fenderwell please...
I connect with voltmeter to pins 3 & 2for ground and only get reading of zero, is idle control unit bad? (battery reads 12volts)
I should be receiving tomorrow the Coolant temp sensor, since I have a mild rough idle now, it was BAD.. now is mostly (well, always on R,P) rough.
this vehicle does not come with electronic idle control VALVE. It is a Euro model
I ALSO don't have a oil temp sensor.
Can't locate idle control unit, looked under dash everywhere, looked under hood by cowl also. any help much appreciated!!
thanks again to all!
any feedback on my rough idle?
pls let me know something.
the only 2 "boxes under the pass side were the AC Temp. control unit (000-822-0903) and AC Blower control unit (000-822-1103)
thanks everyone!!!!
verdejor is offline   Reply With Quote
Old 01-20-2006, 01:26 AM   #2 (permalink)
verdejor's Avatar
RE: ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM
[:(]I get no love in this forum,
or Am I unclear[?]
It's not all that, But it's mine.
Old 01-20-2006, 08:27 AM   #3 (permalink)
Jayhawk's Avatar
Vehicle: S500/W220/2000
FWIW: Your posts are a bit long and complicated. You might try braking them down into several short and pointed posts. I'll bet you get a lot better/more replies.
Love
Jayhawk is online now   Reply With Quote
Old 01-22-2006, 04:46 AM   #4 (permalink)
verdejor's Avatar
I guess I'll do that. If we are categorized by how much we post/reply... I might just be a senior member soon LOL..
YOU r RIGHT THOUGH..
Old 01-22-2006, 09:24 AM   #5 (permalink)
Jayhawk's Avatar
verdejor - 1/22/2006 6:46 AM
No doubt about it!
Old 01-22-2006, 08:41 PM   #6 (permalink)
verdejor's Avatar
by the way, I posted this question, same subject under :
W126 S,SE,SEC,SEL,SD,SDL Class
things are clearing up... I see the light//
