Loosing brake-pressure on Vito -97 - Mercedes-Benz Forum
View Poll Results:
0 0%
Voters: 0. You may not vote on this poll
post #1 of 5 (permalink) Old 01-08-2006, 12:55 PM Thread Starter
Date registered: Jan 2006
Please if anybody have any advice for me.
The brakepedal goes nearly all the way down to the bottom and if I push it again the pedal stops erlier. I have changed the mastercylinder and I have bleeded the system as usual with preessing pedal - open bleedervalve - close and so on but without result. The car is equipped with ABS - could that be a problem? The ABS-unit works properly on ice.
/Marcus
makke_sweden is offline
post #2 of 5 (permalink) Old 01-09-2006, 01:36 AM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
RE: Loosing brake-pressure on Vito -97
acoording to WIS you need to bleeding the system with the star diagnosis connected to the vehicle. see attachment, if pedal still too low, some other procedures included in the instruction.[:)]
benzboyz is offline
post #3 of 5 (permalink) Old 01-09-2006, 08:53 AM Thread Starter
Ok thanks, I guess I have to go to a workshop with my car. Talked to someone today that said there might be a bleeding valve on the "loadingvalve" on the rear axle (that one which take care of the brakeforce depending on the load) - have you any expierience of that?
/Marcus
post #4 of 5 (permalink) Old 01-10-2006, 03:13 AM
benzboyz's Avatar
better follow the instruction since this test step is according to MB experience. And yes I did encounter similar problem like that, we bleed it and it was ok.
benzboyz is offline
post #5 of 5 (permalink) Old 01-10-2006, 01:16 PM Thread Starter
Ok I will go to a workshop and then I hope to get rid of the problem. I just don´t like when I can´t solve the problem on my own but then I have to realize that there is a limit.
Thanks!
/Marcus
