help can i install the wis... i really dont know where i can enter the lan id and license - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-07-2006, 10:15 PM Thread Starter
Date registered: Jan 2006
Next click on the little box that shows a key a window will open, click where it says WIS to highlight the text, then click change, in order to obtain a key you will need to use the provided license program located on cd containing the installation instructions it is the program with the Mercedes Star Icon. Open it or copy and paste it to your desktop double click the star icon once open under application select WIS, then move to the LAN id block and enter the LAN id that is shown on the top of the license over view window, it is not case sensitive, once you enter it select generate, the key will appear on the space at the bottom, highlight the key by holding down the left mouse button and right click it and select copy, move over to where the key is to be entered and right click and select paste, the key will now be entered exactly as it appears on the generator.
Paulwang is offline
