Wiring Harness - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-06-2006, 05:00 PM Thread Starter
Date registered: Nov 2005
Vehicle: 92 600 SEL
Quoted: 2 Post(s)
Wiring Harness
Hi guys,
I'm new to the MB world and keep hearing about the wiring harness that needs to be changes. Can someone briefly explain what it is and what it takes to change it? Thanks
qha000 is offline
post #2 of 8 (permalink) Old 01-06-2006, 08:28 PM
vwbuge's Avatar
Vehicle: 1985 300SD
RE: Wiring Harness
You may be referring to the upper harness on the w124 V8 cars. I am not that familiar so you might want to use the search function.
vwbuge is offline
post #3 of 8 (permalink) Old 01-06-2006, 08:41 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
RE: Wiring Harness
In early to mid 1990s MB tried to be "green" by using biodegradable materials in wiring.
They did.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #4 of 8 (permalink) Old 01-08-2006, 08:09 AM
JR_Rider's Avatar
Date registered: Nov 2003
Vehicle: 1985 300sd
RE: Wiring Harness
Wow. I see you have a 600sel. Yea, you will need a new wire harness, if one has not already been installed. To cut down on costs Mercedes used lower quality wires which become extremely brittle and crack over time, causing exposed wires to make unwanted contact with one another. This causes all sorts of problems, which can only be resolved by replacing the harness. Your cars has a vast wiring harness, as it is a v12. I remember painfully when we had a 95 s600 coupe in the shop that needed a new wire harness. I don't exactly remember the final cost, but is was around $2000. Hope that answers your question.
JR_Rider is offline
post #5 of 8 (permalink) Old 01-08-2006, 08:13 AM
majorkahuna's Avatar
Date registered: Jun 2005
Vehicle: SL320/ML320
RE: Wiring Harness
Get ready to bend over. I replaced mine on my sl320 and it was a couple of grand.
majorkahuna is offline
post #6 of 8 (permalink) Old 01-08-2006, 08:31 AM
Date registered: Dec 2004
Vehicle: '93 300E 2.8
RE: Wiring Harness
As you can see from the previouse reply, this problem also occurred not only on V-8's but also I-6 engines from '93 to about '95.
$2K for the SL320? I thought mine was bad at $1K for my 2.8.
wadman is offline
post #7 of 8 (permalink) Old 01-10-2006, 05:15 AM
pcmaher's Avatar
Date registered: Jun 2004
Vehicle: 1995 S600 (sold)
RE: Wiring Harness
More info...
1995 S600, 1 of 618 (sold)
"Speed is just a question of money...how fast you wanna go?"
Visit my Web Page at http://v12uberalles.com
pcmaher is offline
post #8 of 8 (permalink) Old 01-10-2006, 05:10 PM
lovemyc280's Avatar
Date registered: Oct 2003
Vehicle: 2004 Lexus LS 430 Modern Luxury. 2012 Acura TSX (fun fun) Maybe MB again one day...
Quoted: 61 Post(s)
RE: Wiring Harness
They were all bad from 93-95. Replace ASAP or face more $$$$ down the road. They can fry out your computer if you let it go too far.
You can get a harness at the dealer for about 650 bucks. Should be a couple hours labor. 1k at the dealer sounds about right. 2k sounds way out of line.
lovemyc280 is offline
