Carbon from my tail pipe - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 12-29-2005, 09:29 PM Thread Starter
Vehicle: 300sd Turbo diesel
I have just ran 2 cans of Lubro Moly Diesel Purge through my engine , and changed my fuel filters after doing so. I did this because I had just bought my car (1982 Mercedes 300sd ) and figured since the air filter and oil was neglected so much it need the injectors cleaned as well. Anyway the day after I ran the diesel purge the car was really hard to start(not something that was happening before hand) and when it did it spat out a shi# load of black smoke. Can anyone tell me if this is typical or are my injectors most likely worn?
adrenelin500 is offline
post #2 of 10 (permalink) Old 12-30-2005, 04:19 AM
vwbuge's Avatar
Vehicle: 1985 300SD
RE: Carbon from my tail pipe
You need a good italian tune up and things will be fine.
vwbuge is offline
post #3 of 10 (permalink) Old 12-30-2005, 06:19 AM Thread Starter
I took the car for a 100 k ride twice since using the purge, leaning on the engine quite alot and still this morning it is hard to start.There is also still the smoke issue upon starting.
post #4 of 10 (permalink) Old 12-30-2005, 06:31 AM
matteus's Avatar
Date registered: Jan 2003
Vehicle: Mercedes-Benz
how many miles are on the engine?
It's possible that the diesel purge has removed any carbon deposits which were at places where they functioned as an oil seal. think piston rings, cylinder walls, valve seatings, etc. By removing all the deposits, you let oil run around more freely, sometimes places it shouldn't run.
perhaps you should try to put in thicker oil, such as 20W50 or SAE30 and see what happens.
The hard starting may suggest compression loss. This can be caused by worn out piston compression rings. If the engine was run with a really dirty, or even no airfilter, the cylinder walls may be warped out.
1991 MB 300TD: daily driver, going strong at 474.000kms
1991 MB 190E 1.8
1983 MB 190E 2.0 AMG 145PS: Restauration project up next...
2001 Alfa Romeo 147 2.0 16V Selespeed
matteus is offline
post #5 of 10 (permalink) Old 12-30-2005, 08:06 AM
tuttebenne's Avatar
Date registered: Jul 2005
Quoted: 262 Post(s)
If you are truly getting black smoke from the tailpipe it sounds more like an extremely rich mixture. You might have to have someone inspect the performance of the fuel distributors and injectors.
tuttebenne is offline
post #6 of 10 (permalink) Old 12-30-2005, 09:04 AM
zaphodsplanet's Avatar
Date registered: Jun 2005
Vehicle: 04-E320 (benz #7)
Send a message via Yahoo to zaphodsplanet
adrenelin500 - 12/29/2005 11:29 PM
Not exactly sure what your problem is but I'd recommend you check out mercedessource.com I used them for all sorts of stuff with the two W123's I owned. The guy who owns it may also be of help in narrowing down your problem... he helped me before. They also have a lot of great DIY kits and manuals.
It does sound as if you are running too rich. If the thing was leaking a lot of oil internally you would be puffing out a lot of white/blue smoke... not black. You could also have a bad glow plug or two. If you have a meter check them out. Do do this you just need to make contact on the end where the wire connects... and to the engine block someplace. If you get some kind of reading it's good. if not it's bad. Changed them all out on the last 123 I had and it made a huge difference in startup. Stopped the immediate smoking... and it actually started up all the way ... right away... instead of sounding like it was running on 2 cylinders... then 4 and then 5. The glow plugs are on the drivers side of the engine.
Take care,
Z
zaphodsplanet is offline
post #7 of 10 (permalink) Old 12-30-2005, 05:59 PM
tuttebenne's Avatar
Quoted: 262 Post(s)
Ahhhhh. That brings back fond memories of my 123...
post #8 of 10 (permalink) Old 12-30-2005, 06:34 PM
tuttebenne - 12/30/2005 7:59 PM
LOL... it really does doesn't it?...you must know from where I speak friend....LOL....
sometimes I miss Stinky (it's nickname) Miss having to pop the hood to shut it off.... I miss the trail of smoke.. or maybe I just miss having a car that I could honestly call "Stinky"....LOL the 123 are great cars though.
They do have nice lines though don't they.... hey... found a pic of stinky....
post #9 of 10 (permalink) Old 12-30-2005, 10:28 PM Thread Starter
Thanks for the info everyone, I think I'll start with the injectors first tutte. It was my first suspect anyway.
post #10 of 10 (permalink) Old 12-31-2005, 09:12 AM
tuttebenne's Avatar
Quoted: 262 Post(s)
"Stinky." I fully understand. Great name! I wasn't half as creative when I named our 123 wagon "Greenie." It was this unusual nonmetallic color called Eibengrun. I loved that car and will post a pic when I locate one. I used to kid one of my buddies by saying "Joe, there's nothing like the smell of diesel exhaust in the morning!"
Best wishes,
Andy
