engine won't stop!! - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-28-2005, 09:17 PM Thread Starter
engine won't stop!!
Here is the problem[:O]. I recently acquired a 1984 190D. When I got the car it needed a new starter motor as the old one was shot and would not work. I put the stator motor in, not an easy task. Now the engine starts up fine but when I turn the key to turn the engine off it does not kill the engine…[:(!] I was told by the previous owner that the engine started and stopped fine before the startor motor went. I can remove the key and the engine keeps on running. Lucky it is a manual so I can stall it to kill the engine. Has anyone ever had such a problem? Where do I look? What do I do? I have never owned a diesel and am not familiar with them at all! Any help would be greatly appreciated. Thank you .
evelyn tremble is offline
post #2 of 9 (permalink) Old 12-28-2005, 09:25 PM
Date registered: Aug 2005
Vehicle: 1985 300 SD
RE: engine won't stop!!
Thatis good. It will save wear and tear on your starter, keep your battery charged and will keep the engine and radiator from freezing. If garaged, it will also kill any rats or other vermin.
Your fuel economy will suffer, though. YMWNV
Your mileage will not vary.
Joe.
evelyn tremble - 12/28/2005 10:17 PM
jbleaux is offline
post #3 of 9 (permalink) Old 12-28-2005, 10:17 PM
vwbuge's Avatar
Vehicle: 1985 300SD
I am pretty sure you have a vacuum leak somewhere. Probably knocked a line off when replacing the starter.
vwbuge is offline
post #4 of 9 (permalink) Old 12-28-2005, 10:34 PM
Sorry for the flippant answer Evelyn.
For some reason, all I saw of your post was : "car won't stop". Now, I have seen the post in its entirety and I agree about a vacuum line being off.
Joe
jbleaux is offline
post #5 of 9 (permalink) Old 12-29-2005, 10:30 AM
zaphodsplanet's Avatar
Date registered: Jun 2005
Vehicle: 04-E320 (benz #7)
Send a message via Yahoo to zaphodsplanet
Yes... I agree that you have a vacuum leak. Like the previous person said... the first place I would check would be around the starter. Look for hard plastic lines that may have come out of rubber lines. Check along the top of the engine too.... if someone wasn't careful in the repair they could have knocked off a line... or god forbid.... broke an old plastic part. I've had 2 300D's.... an 82 and an 83.... this was always something I ran into...good luck and let us know if you find the leak..
Jeffrey
Ops... almost forgot.... if you don't have one go and get a vacuum gauge... they have them for around $10-15 at most auto parts stores.... it will help you find the leak or bad vacuum element.
zaphodsplanet is offline
post #6 of 9 (permalink) Old 12-29-2005, 07:10 PM
benzboyz's Avatar
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
try to recheck the area when you install the starter you might accidentally remove some vacuum lines.
benzboyz is offline
post #7 of 9 (permalink) Old 12-29-2005, 08:29 PM
tuttebenne's Avatar
Date registered: Jul 2005
Quoted: 241 Post(s)
You might be wondering why everyone is so concerned about vaccuum if the engine won't stop. The fuel distributor (the heart of a diesel) reguires a method that shuts off fuel in order to stop the engine. There is a vaccuum line that is routed to the ignition switch that allows vaccuum to flow to the fuel shut off diaphragm on the distributor. If you have a leak in the vaccuum system there will not be sufficient vaccum to shut of the engine. The 300D and 300E models use vaccuum to lock and unlock the doors; this is the most likely source of a leak in the 300s. I don't know if this is the same with your 190D but a simple vaccuum leak is a likely suspect. PS: there is a manual shut off on the throttle linkage indicated as a red "stop" sign on a flat tab of linkage - push this red tab and the fuel will manually be shut off. Best of luck and welcome to the forum.
tuttebenne is offline
post #8 of 9 (permalink) Old 12-30-2005, 02:59 PM Thread Starter
Indeed vacuum hoses! I took off the air filter and found two vacuum hoses that where off. One was cut and the other one was off completely. Reattaching them has solved the not so mysterious mystery of the runaway engine....
Thank you to all of you who helped!
This forum is awesome.
HAPPY NEW YEAR!! to all out in Mercedes Land!
post #9 of 9 (permalink) Old 12-30-2005, 06:09 PM
evelyn tremble - 12/30/2005 3:59 PM
Totally Awesome Evelyn.... glad you found it.
Mission Accomplished....
Happy new year to you too....
Jeffrey
