» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 12-28-2005, 01:16 AM   #1 (permalink)
Vehicle: ´01 E320CDIT,´77 200
Some issues on a W210 E 320 CDI T, heater and diesel smell
Hi guys!
Hope you had a merry x-mas.
There are some issues on my E 320 CDI T, W210, model 5/2001, which I hope to get some help for here....
1.) the cars smells like Diesel on the outside, even if parked 2 days and nights. There is almost no smell inside and no diesel is leaking on the street.
The performance of the car is o.k., the gas consumption is about 9-12 litres diesel / 100km.
2.) The heater does not pour air out of the two outlets in the midle of the dashboard and at the lower outlets for the feet. No cold and no hot air.
The heater works as the two outlets at left and right on the dash pour hot and cold air as they should.
I guess there are some air-guides stuck in the dashboard.
Do you have an idea how to fix this? Is this a typical problem with these 210 models?
The car stood at the dealership for 18 month before I bought it. Maybe this info is of help.
I tried to adjust the outlet position manually with the possibilities the automatic ac controller gives me, but nothing was changing.
The rest of the car works perfectly, the mileage is 60.000 Km and the general condition is 2. So it is not a worn out pice of junk.
The car is equipped with an automatic air condition and a normal CD player (not manual, no command).
Maybe you got an idea for me as it is pretty cold here in southern Germany at the moment and I would like to warm up my feet a bit....
Thanks a lot in advance and kind regards!
Mathias
matzhinrichs is offline   Reply With Quote
Old 12-28-2005, 12:03 PM   #2 (permalink)
Vehicle: W211 E320CDI & V221 S320CDI
RE: Some issues on a W210 E 320 CDI T, heater and diesel smell
Hi, I've had a W210 E320CDI some time ago, it did average a lot less than 9-12 litres / 100km. I've done with a W211 E320CDI 7.1 to 7.2 l/100km, including long, true winter time in the north (and the CDI consumes quite a lot more when it is cold, say -5 to -15 degrees Celsius). W211 is perhaps 0.5 litters / 100km better than W210. Or are you doing only city driving in Munich? Would expect some leak, but then again, losing a litre or more per 100km is quite a big leak. And the car is too young for a leak, hasn't been hit by a traffic accident or something?
Old diesel engines had pipes that carry excess diesel back from injection nozzles (sorry, don't know the correct terminology), those often started leaking at 100 000km. Haven't had a look at my car, but from www.jesmb.de, I find similar pipes on a new CDI. Still, my W210 did not leak at 64 000km (when I sold it). Anyway, even diesel would mostly evaporate when it leaks over the engine. Would suggest taking the plastic covers out and see what happens when the engine is running.
The centre outlets hardly get open for heating if driven automatically by the car (the lower ones certainly should). Mainly open at summer to let cold air out. If you have the automatic AC, with an LCD display, you can run it on a diagnostic mode and control each air valve independently, perhaps some are stuck, from a long stay at the dealer (I wouldn't really expect that though). I'm not sure if I dare to send the MB originated info through the forum, could send by email, but the info may be found from internet already. Might be useful to check that there is sufficient vacuum to drive the vents.
Diesel Benz is online now   Reply With Quote
