Fog Lights - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-17-2005, 10:10 AM Thread Starter
DGMond's Avatar
Date registered: Jan 2005
Fog Lights
I am putting fog lights on my 2001 ML320. Can someone please tell me know where do I plug them in so they will work off the factory dash switch? I was told there is a plug behind the head light assemblies. However, I have been unable to find out exactly where they plug in. Performance Products sells a light kit that is suppose to directly plug into these receptacles. But I want some more info before I make the purchase.
DGMond is offline
post #2 of 2 (permalink) Old 12-19-2005, 09:32 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
RE: Fog Lights
I dont know about a 01, but my ex 99 had a two wire connector behind the headlamp/washer reseroir tank it had a plastic cap over it. My 99 had the bulbs for the fogs removed in the headlamps since it did not meet FL DOT. I had to go to the dealer and tell them I was hooking up the auxilliary lights mounted on the bar before they activated the feature. That cable is in parrallel to the headlamp mounted bulbs, I dont know when they changed, but it is a computer driven switch from the "All Activity" computer and had a bulb in the dash and on the switch that can be activated (some did not like the dash indicator). The connector is what they call a "Weather Pak" connector at all good auto stores. There was some rumbling about overloading using the bulbs and the aux.
The 163 page might shed some light, I dont usually go there due to my ML disatisfaction. MB sold a cable for their lights you might finfd one at some MB body shops if they repaced the auxlights but not the cable I found one.
Peter Guenther is offline
