HELP - blower motor doesn't run ! - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-06-2005, 08:33 PM Thread Starter
124via126's Avatar
Date registered: Oct 2004
Vehicle: 85 300SD, 95 E320
how do you get the blower motor out?
can someone post instructions (with pics if possible)
i am having some problems with the heater.
here is what i know and am experiencing:
blower motor fuse (long metal 30A) is intact;
push button controller seems to work since i hear the vents open/close when selected;
warm air comes out of the side vents when the car is moving but not when car is still;
there were some squeeking sounds coming from what i suspect was the blower before it completely stopped;
i had the dust filter replaced by the dealership couple months ago. is it possible that the filter may be improperly installed and dislodged?
could the bearings just need lubrication? i read ATF fluid being used but will sythetic motor oil work as well?
1985 300SD Turbo Diesel - 299,xxx km (1/2015)
1995 E320 - 301,xxx km (1/2015)
124via126 is offline
