noob question about kompressors - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-06-2005, 05:54 PM Thread Starter
hey everyone,
i am thinking about buying a mercedez benz slk.
are the slk kompressor series turbocharged?
twoquik is offline
post #2 of 9 (permalink) Old 12-06-2005, 05:57 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
RE: noob question about kompressors
Welcome to the forum.
In answer to your question: nope.
Kompressor means SUPERcharged, not turbocharged.
Check Codes is offline
post #3 of 9 (permalink) Old 12-06-2005, 06:03 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
From Motoring magazine:
'What’s the “Kompressor� badge on that C200 all about? A supercharger is one way of improving engine efficiency, and therefore the power output of an engine. The supercharger uses a ‘Kompressor’ or compressor, driven by the engine’s crankshaft, to literally force-feed the combustion chambers with the air-fuel mixture. This fills the cylinder spaces more completely and produces a much bigger output, as opposed to a naturally aspirated induction system (as in the C180’s engine) which has to (rather weakly) suck the mixture in.'
jdc1244 is offline
post #4 of 9 (permalink) Old 12-06-2005, 06:08 PM Thread Starter
what upgrades are available? has anyone put aftermarket superchargers on their car?
i would think there isnt much room for moddifications.
are they rear wheel drive?
twoquik is offline
post #5 of 9 (permalink) Old 12-06-2005, 06:28 PM
Riquiscott's Avatar
Date registered: Aug 2005
Vehicle: 1972 250C, Ducati ST
You can still make improvements, even with a supercharger, but the engine will respond differently to modifications than a naturally-aspirated engine will.
For instance, cylinder head porting doesn't have as much of an effect on a supercharged car. Since the air is being forced into the engine under pressure, you don't have to "port and polish" the intake runners to "coax" the air in. They can, however, still benefit from less-restrictive intakes, as well as intercoolers or aftercoolers.
You can still raise the static compression ratio for more performance, but you can't raise it as far without running into pinging problems because the supercharger is already increasing the dynamic compression significantly.
Nitrous works fine on supercharged engines, and the cooling effect of the expanding nitrous oxide actually offsets some of the temperature increase from the supercharger compressing the air.
The simplest improvement for supercharged engines comes from changing the pulley ratio to get more boost from the supercharger. By fitting either a smaller supercharger pulley or a larger crankshaft pulley, the supercharger will generate more boost for a given engine RPM. You still have to keep the boost levels reasonable, or else you'll run into pinging/detonation and overheating, though.
Scott
Riquiscott is offline
post #6 of 9 (permalink) Old 12-09-2005, 03:28 PM
BILLSONG's Avatar
Date registered: Sep 2005
Vehicle: 03 ML500, 94 CADILLAC DEVILLE CONCOURS, 350ZR
twoquik - 12/6/2005 5:08 PM
Yes all Benz are RWD[:)]
BILLSONG is offline
post #7 of 9 (permalink) Old 12-09-2005, 05:23 PM
jdc1244's Avatar
Or all wheel drive, thank goodness. If DCX goes front wheel drive then it’s truly the end…
jdc1244 is offline
post #8 of 9 (permalink) Old 12-09-2005, 05:50 PM
asianml's Avatar
jdc1244a - 12/9/2005 7:23 PM
Let's just hope they're not thinking about it.
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #9 of 9 (permalink) Old 12-10-2005, 09:47 AM
matteus's Avatar
Date registered: Jan 2003
Vehicle: Mercedes-Benz
asianml - 12/10/2005 1:50 AM
A-class...
1991 MB 300TD: daily driver, going strong at 474.000kms
1991 MB 190E 1.8
1983 MB 190E 2.0 AMG 145PS: Restauration project up next...
2001 Alfa Romeo 147 2.0 16V Selespeed
matteus is offline
