Help with Timing Chain - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-06-2005, 04:07 PM Thread Starter
Date registered: Nov 2005
Hi I just took every thing apart on my 190 2.6 because the timing chain jumped, and Im trying to find how to set the timing again. I cant figure out where to line up the crank and the cam sprocket. Does any one know. Thanks
raif is offline
post #2 of 7 (permalink) Old 12-06-2005, 04:59 PM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
RE: Help with Timing Chain
Crankshaft timing should be on top dead center (OT) while the camshaft marling should align with the top marking in the cylinder head, refer to the picture included
benzboyz is offline
post #3 of 7 (permalink) Old 12-06-2005, 05:06 PM
benzboyz's Avatar
sorry about that I'm not so sure I upload the picture but here it is again.[:D]
benzboyz is offline
post #4 of 7 (permalink) Old 12-06-2005, 06:24 PM Thread Starter
Ok so the things on the cam should be pointing to the head I see that. But Im still confused about the crank shaft where to meet. This is big help thanks for the info its better than me guessing.
raif is offline
post #5 of 7 (permalink) Old 12-06-2005, 07:35 PM Thread Starter
benzboyz - 12/6/2005 7:59 PM
For the crankshaft how do I find the top dead center. Do I have to have the timing cover on to find out.
raif is offline
post #6 of 7 (permalink) Old 12-11-2005, 10:30 PM
benzboyz's Avatar
the left side of the crankshaft sensor bracket will be basis or the pointer for the "OT" or top dead center.
So sorry for the late reply
benzboyz is offline
post #7 of 7 (permalink) Old 12-11-2005, 10:34 PM
benzboyz's Avatar
No need to remove the timing case cover you can see this directly in the pulley. on a W201 2.6 it might be a little difficult to see, since space is too small in that area.But its possible to check this.
if you look in the lower left of the picture the OT mark is in the vibration damper itself all you have to do is just turn the damper and you will later see this mark, then align it with the crank position sensor bracket.
benzboyz is offline
