2-4 times after glow to start 300sd - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-05-2005, 10:48 PM Thread Starter
Vehicle: 1992 400E
Send a message via Yahoo to longwaited
I have purchased my first mercedes, 1984 300sd. Every thing works great except when I try starting after glow light goes out. It has new battery and alternator. The problem does not happen every time, however sometimes I will have to turn the key off then wait for the glow light to go out and repeat this process sometimes 2-4 times. Every time I hear a click under the hood when this happens. It runs great when it does start. I would like to find out what the problem could be before I get stranded some where.
Thanks, longwaited [8D]
longwaited is offline
post #2 of 7 (permalink) Old 12-06-2005, 07:18 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
RE: 2-4 times after glow to start 300sd
Start by taking an ohm meter to the glow plugs. Good ones read 0.6 ohms cold.
Len
sokoloff is offline
post #3 of 7 (permalink) Old 12-08-2005, 09:43 PM
Date registered: Jun 2005
Vehicle: 2005 E320 cdi
I agree with sokoloff. Just because the glow plug light operates on the dash and you hear the relay click it doesn't mean that the plugs are functioning. They do wear out over time. I've experienced the same situation with volvo and audi diesels in the past!
junkman is offline
post #4 of 7 (permalink) Old 12-10-2005, 01:53 AM Thread Starter
Vehicle: 1992 400E
I may have not have ask my question correctly. When my glow light goes out and I turn the key the engine does not turn over, I have new glow plugs, When the glow plug light goes out and I turn the key all I hear is a click under the hud. This does not happen every time I try to start the car. This happens occasionally when the engine is cold or fully warmed engine. What should I check. Since this is my first mercedes, 84 300sd. I can compare the problem to a bendix problem on the starter on other cars I have owned. Is there a relay on an 84 300sd, before voltage is delivered to the starter ? If not should I have the starter checked out. I also have checked my ground, it is clean and grounded well.
I would appreciate any advise on this matter.
Thanks, longwaited
post #5 of 7 (permalink) Old 12-10-2005, 04:31 AM
benzboyz's Avatar
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
Maybe your solenoid switch on the starter itself has problem.
benzboyz is offline
post #6 of 7 (permalink) Old 12-14-2005, 09:59 PM
Sorry-I got your PM but could not get the system to reply. I checked the oreilly's web site. Benzboy gave you some good advice. The solenoid is $17 bucks for your car. I'd change that first. If that doesn't fix the problem, have the starter tested. Oreilly's lists the starter motor for $79.00. i wish the parts for my 05 cdi were that cheap. Check the connections at the solenoid and starter as well. A loose wire will cause the same problem.
Hope that helps!
junkman is offline
post #7 of 7 (permalink) Old 12-17-2005, 05:33 AM
84300DTurbo's Avatar
Date registered: Sep 2004
Vehicle: 1984 300D Turbo
this is a common phenomena. i have had it for years, but usually when the engine is hot. cycling the key switch has never failed to eventually engage the starter
so i live with it.
a new starter/solenoid has cured the problem permanently for others.
if you do go for a new starter go with an OE bosch rebuilt.
good luck with your new purchase they are great cars.
1984 300D Turbo - 231k.. son's car now... totalled 11/30/07 RIP
send lawyers, guns, & money...
84300DTurbo is offline
