valve clearance - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-02-2005, 11:15 PM Thread Starter
Date registered: Nov 2005
valve clearance
so i am doing my first valve adjustment on an 81 300d...and i'm not sure as to exactly how to use the feeler gauge correctly, should the gauge be able to go all the way thru between the rocker arm and lobe to the other side or just part of the way in...and does it matter if i measure from the passenger side or the drivers side??
elgatoensombrero is offline
post #2 of 2 (permalink) Old 12-03-2005, 02:01 AM
vwbuge's Avatar
Vehicle: 1985 300SD
RE: valve clearance
You should be able to insert the feeler guage the entire way in. It should slide fairly easy with a little bit of resistance.
vwbuge is offline
