'99 E320 Intake Air Temperature Sensor MOD. Check Engine Light now. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-27-2005, 11:34 PM Thread Starter
Date registered: Nov 2005
I have replaced a module from http://www.20horsepower.com/. Mercedes has 5 wires coming out of the IAT Sensor. The unit has 4 wires, 2 on each side of the unit. I have connected back 3 wires to their original wire and plugged the remaining2 wires to conenct to the mod unit. I thought I new with a voltmeter which was postive and which was negative. Everything seems to be running fine , except the increase in 20 HP, but I now have a "Check Engine" light on. I have pulled th battery cable to reset things. I just want to get rid of the check engine light... Does anyone know the colors codes of the wires? Which is + and which is -?
Any help is appreciated.[:(]
jdupree is offline
post #2 of 4 (permalink) Old 11-29-2005, 02:53 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
RE: '99 E320 Intake Air Temperature Sensor MOD. Check Engine Light now.
Welcome to the forum.
I'd be very surprised if anyone is going to have the specialized knowledge you need.
My humble recommendation -- having been through things like this on other cars -- is to go back to the manufacturer that sold the thing; it's their responsibility to get it working properly.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 4 (permalink) Old 11-29-2005, 09:48 PM Thread Starter
Thanks for the reply and the advice.
jdupree is offline
post #4 of 4 (permalink) Old 11-30-2005, 07:38 AM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
Welll.... You got screwed - that thing nothing but 10 cents resistor. What it does is changes readings from MAF - your ECU found readings out of normal and turn CEL on.
My advice - get rid of that thing and revert to stock setup.
Kirill
Kirill is offline
