Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 11-24-2005, 07:27 PM   #1 (permalink)
Date registered: Apr 2005
Vehicle: 1980 240D
pull engine to replace injector?
A friend of mine has a 99 E series turbo diesel, one of the injectors is leaking and needs to be replaced. Her mechanic, (not a dealer) told her the engine must be pulled to replace it. That sounds a little extreme to me. Is this true, if not is it a big deal?
Thanks
80 240D
gigem75 is offline   Reply With Quote
Old 11-24-2005, 08:27 PM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 1985 300 SD
RE: pull engine to replace injector?
I could be mistaken but it looks like this is another person to be brought to the public's attention.
I seriously doubt Mercedes would design a car whereby one would have to pull the engine to remove/replace an injector. Is this mechanic willing to put this in writing.
Sidenote: I would cut a hole in the member that is preventing removal and then close the hole through various means.
Joe.
gigem75 - 11/24/2005 8:27 PM
Thanks
80 240D
jbleaux is offline   Reply With Quote
Old 11-25-2005, 06:32 AM   #3 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Vehicle: 1990 300 SEL
I dont know a lot about this subject, but it sounds fishy to me. Have her take the car to another mechanic.
Mike
Mike
1990 Mercedes Benz 300 SEL
2001 Mercedes Benz ML320
1999 Mercedes Benz SLK230
1986 Porsche 911 Carrera
Michael Pillay is offline   Reply With Quote
Old 11-25-2005, 07:17 AM   #4 (permalink)
Premium Member
cmitch's Avatar
Vehicle: '99 ML 430, 2002 ML320
Premium Member
I've known of a few shady mech's that take loose motor mounts and manipulate the position of the engine so they can work on it as "Pulling the engine". Find another mechanic!
cmitch is online now   Reply With Quote
Old 11-30-2005, 08:22 PM   #5 (permalink)
every 99 e class diesel i have worked on the intake manifold has to come off to reseal the injector. it is pretty common for the injector seals to leak, not that expensive of a repair. off the top of my head i think its about 3.5-4.0 labor. i would also rec replacing all the plastic fuel lines around the injectors because every time you touch them they seem to leak or break.
benzmech is offline   Reply With Quote
Old 12-01-2005, 12:49 PM   #6 (permalink)
BILLSONG's Avatar
Date registered: Sep 2005
Vehicle: 89 300SE-03 ML500
Send a message via AIM to BILLSONG
Baloney.
I HAVEN'T BEEN ABLE TO BE ON FOR QUITE A. WHILE. 2 YEARS? I WILL START TO WORK AND MODIFY MY DIY STICKY AS SOON AS THE BEGINING OF DEC. MOST OF THE LINK DOESN'T WORK ANYMORE. PLEASE DROP ME AN EMAIL ABOUT NEW PICTURE/DIAGRAM, AND ALSO ANY LINK THAT SHOULD BE ADDED. WILLIAMRSONG@GMAIL.COM. BILLSONG
BILLSONG is offline   Reply With Quote
Old 10-16-2008, 07:18 PM   #7 (permalink)
Date registered: Sep 2008
Vehicle: 1983 Euro 500sel, 1991 190e 2.6, 1981 380sl
I agree with benzmech-having been a M-B tech for years, I can tell you the only thing that needs to be removed is the intake manifold
jmpianowski is offline   Reply With Quote
Old 10-16-2008, 07:36 PM   #8 (permalink)
johnhef's Avatar
Date registered: Mar 2007
Vehicle: 84-300TD-Euro 87-300D 80-500SE 82-380SEL 83-380SEC 84-500SEC 84-500SEC-Euro 86-560SEL-Carat 06-R350
Send a message via AIM to johnhef
to remove/reseal the pump yes the intake manifold needs to come off. the injectors themselves are under the plastic cover on top of the head.
johnhef is online now   Reply With Quote
Old 10-16-2008, 10:19 PM   #9 (permalink)
pmark3100's Avatar
Vehicle: 1982 M-B 380SL, 1984 Dodge W-150, 1990 Toyota Camry, 1999 Kawasaki Concours
Actually, I can think of something else that needs to be removed. The nut on the other end of that wrench. While field servicing is often a poor second to quick assembly, I can't see an engine needing to be removed for something that might need service under warranty.
pmark3100 is offline   Reply With Quote
Old 10-16-2008, 10:32 PM   #10 (permalink)
~BANNED~
Date registered: Apr 2008
Vehicle: The fleet: 2001 CLK430 Cabriolet, 1997 Jaguar XJ6L
You mean they alter the postion of the engine mounts to make it look like the engine was removed?
Original poster, follow everyones advice and tell your friend to get a second opinion. I could not imagine the engine having to come out with a V6 engine to change an injector let alone an inline 6.
CLK Operator is offline   Reply With Quote
