Crank but no start on my 190e benz - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 11-18-2005, 01:16 PM Thread Starter
Date registered: Nov 2005
Hi I have a 1990 190e 2.6 5sp benz. The car cranks but it wont start. Its getting fuel and spark but it just wont start. Does any one have a clue what could it be. Changed the plugs wires cap and roter and still nothing. If any one could help me out that would be great. Thank you
raif is offline
post #2 of 9 (permalink) Old 11-18-2005, 04:18 PM
~BANNED~
deathrattle's Avatar
Date registered: Jan 2005
Vehicle: 1992 W126 300 SE
Quoted: 2 Post(s)
RE: Crank but no start on my 190e benz
How do you know it's getting fuel? Are you sure?
deathrattle is offline
post #3 of 9 (permalink) Old 11-19-2005, 08:27 PM Thread Starter
I took a fuel line off and its spraying fuel every where. I have no clue what it could be.
raif is offline
post #4 of 9 (permalink) Old 11-20-2005, 02:56 AM
~BANNED~
Quoted: 2 Post(s)
So far I'm stumped.Perhaps you can explain more details like what happened in the lead up to the problem.
post #5 of 9 (permalink) Old 11-21-2005, 02:12 PM Thread Starter
I was driving to school and if you gave it more than 50% throttle it will just start braking up really bad. If you just gave it a little gas if would be fine. All of the sudden the car just died. I cranked for like 5 min and it started again got me home it was rough but got me home, then the next day if was all done, it wound start at all.
I was thinking that the timing has jumped on it, while the car was still hot is ran a little bit but as soon as it got colder it wont start again. The motor compression is 180 across the board so it not the motor.
raif is offline
post #6 of 9 (permalink) Old 11-21-2005, 03:38 PM
~BANNED~
Quoted: 2 Post(s)
Well it still sounds more like fuel to me,so if you are getting full pressure up the line,maybe you have blocked injectors?
These engines are notorious for relay problems as well,so it's worth giving the FP and OVP relays a whack and a wiggle-ie make sure there is no corrosion or dampness on the contacts.
post #7 of 9 (permalink) Old 11-23-2005, 10:01 AM Thread Starter
Where would this 2 relays be located at. I took all of the injectors out and they seem fine but I can’t make sure.
raif is offline
post #8 of 9 (permalink) Old 11-23-2005, 10:38 AM
Riquiscott's Avatar
Date registered: Aug 2005
Vehicle: 1972 250C, Ducati ST
Try inspecting a spark plug after you've cranked it for a while. If the fuel is making it all the way to the combustion chamber, the plugs should be wet.
Scott
Riquiscott is offline
post #9 of 9 (permalink) Old 11-23-2005, 05:52 PM Thread Starter
Yup, all the spark plugs are getting wet. So they are all getting fuel.
raif is offline
