1986 190e Motor exchange - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-15-2005, 11:18 AM Thread Starter
Date registered: Nov 2005
Hello: I'm new to the forum and have a question. Can you put the m103 inline 6 into a 86 190e 2.3. I've heard you can do this on models 1989 and above. Just wanted to check with you guys and get your thoughts on the matter. My current engine runs fine other than the small oil leaks. Head gasket probably bad. I really think the bigger motor would be a kick.. Thank you.. JS
hellboy66 is offline
post #2 of 6 (permalink) Old 11-15-2005, 04:18 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
RE: 1986 190e Motor exchange
You will have to replace the radiator and a/c condensor, the radiator support and fans. You will also need to change the front springs for the additional weight; the a/c system will be different, as well as the engine electronics. Considering the time and expense, you may as well just buy a used 2.6L 190E . . . or if you're dead set to do a swap, go all the way to the 3.0L M103 or the twin cam M104.
MTI is offline
post #3 of 6 (permalink) Old 11-16-2005, 08:28 AM Thread Starter
I see your point and I appreciate your advise. Thank you..
post #4 of 6 (permalink) Old 11-16-2005, 09:38 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
I was at Motorwerks this summer and they had a project modifying a w124. Cant remember what they were putting in, but it looked impressive.
Mike
Mike
Michael Pillay is offline
post #5 of 6 (permalink) Old 11-17-2005, 10:24 AM Thread Starter
If there was a way to put a e420 motor in my 190e i would. Seems scary, but sounds fun...
post #6 of 6 (permalink) Old 11-18-2005, 10:24 AM
AMSOIL300CDT
Guest
Posts: n/a
Quoted: Post(s)
hellboy66 - 11/17/2005 12:24 PM
that would be basicly, from performance/handling/size, an "early model" C-43 AMG........[:D]
