Just bought a 1985 300D - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 11-15-2005, 08:40 AM Thread Starter
BENZ4LIFE!'s Avatar
Date registered: Nov 2005
Vehicle: 1985 300D
I am very new to this whole forum thing?!...So, I just bought an 85' 300D!! Very excited! Picked it up for very little money and hoping to make this vehicle last me a very long time!!! What are some of the problems I should be aware of with this car?? I am considering changing the stereo out first...Is this easy? The car has 205K on it and hums along just fine...It has a replaced tranny as of maybe 4 months ago...The heating unit is acting funny?! It will blow hot for about 5 min and then goes cold?? Please help me fellow benz lovers!!!
BENZ4LIFE! is offline
post #2 of 13 (permalink) Old 11-15-2005, 08:59 AM
Gareth Coe's Avatar
Date registered: Oct 2005
Vehicle: 404S
RE: Just bought a 1985 300D
Well, as you're new let me say...
WELCOME [:D]
As for those technical type questions: I can't help you myself coz I'm a Unimog-man [xx(]. I'm sure someone out there in forum-land has all the gen for ya.
Have fun [;)]
Gareth
http://heidilandrover.webeden.co.uk
VJMC EMLRA EAFVG
Gareth Coe is offline
post #3 of 13 (permalink) Old 11-15-2005, 09:03 AM Thread Starter
BENZ4LIFE!'s Avatar
Vehicle: 1985 300D
Thanks for the welcome!! I checked out your site...pretty cool stuff!![:D]I am really excited about this car...I owned a 99 c230 sedan before this and I loved that car as well so I'm hopin to get some help on what to do with this new beast! ttyl! Thanks again!
post #4 of 13 (permalink) Old 11-15-2005, 10:42 AM
Vehicle: 1996 210.020
Your heater problem sounds like the monovalve. Replace or rebuild it. Running with the selector on max heat may prevent interruption for now.
The stereo form factor is standard DIN. If you install a new head unit, be careful about using the funky sheet-metal mounts that are usually included. Installation may make removal of the wood panel (above the stereo) next to impossible. You need to be able to access the two small screws at the bottom of this panel.
Matt L is offline
post #5 of 13 (permalink) Old 11-15-2005, 10:53 AM Thread Starter
BENZ4LIFE!'s Avatar
Vehicle: 1985 300D
Thank you so much for replying! As far as the heater...I've been doing that and the heat is just plain cold air now![:(!]So...I guess I'll have to look into the monovalve issue. As far as the deck...you're saying any standard DIN should work? I don't have to worry about any crazy special cables...beyond the normal kits that comes with the stereo kits? Are speakers really easy to replace??
post #6 of 13 (permalink) Old 11-15-2005, 12:29 PM
Ask for cables for a '85 300D, of course. Yes, you'll need special cables, but that's a given for any car with an aftermarket head unit.
Note also that you have a fader control behind the shifter lever. Any aftermarket unit will have this built-in, so you may wish to disconnect that control and wire up the speakers directly to the head unit. Your call there.
I've not replaced speakers on a W123, but speaker installation is usually much more involved than head unit installation. If you found elements with the same form factor (physical size, mounting hole locations, etc) as stock, it would be quite easy.
Matt L is offline
post #7 of 13 (permalink) Old 11-15-2005, 12:39 PM Thread Starter
BENZ4LIFE!'s Avatar
Vehicle: 1985 300D
Alright!![:)]Sounds awesome! I'll def be replacing the head unit most likely this weekend...I am now truly starting to consider a possible restoration project for this car...I really like the car and the classic feel of it I guess...lol! I am hopin this car last me a while....never owned a Diesel before so I guess this will be a learning experience!![:p]Thanks again!!! And please...keep the info flowin in...I need all the heads up I can get!
post #8 of 13 (permalink) Old 11-20-2005, 05:38 AM
JeepersCreepers's Avatar
Vehicle: '91 420SEL '80 300TD
205k? I assume you want to replace the timing chain if it hasn't been done. I recently did that on my '91 420SE/L for about $600 parts and labor. I am not sure if this applies to diesels, but I have been told that it is must for a V-8 from this era.
JeepersCreepers is offline
post #9 of 13 (permalink) Old 11-21-2005, 05:10 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
This is for a w126 monovalve repair. I assume your repair will be similar. The repair kit can be purchased for about $20 to $30 from benzbin.
http://mbdieseldiy.tripod.com/monovalve.htm
Mike
Mike
Michael Pillay is offline
post #10 of 13 (permalink) Old 11-23-2005, 07:09 AM
Vehicle: 1985 Mercedes 300SD
I just bought a 1985 300SD on Monday. I got it for a good price and am hoping to enjoy it. It has a few quirks in it that I will need to fix as time goes by but figured that with a 20 year old car.
I am also hoping to get years of enjoyment out of it. I will be interested to hear how you get along with your 300D over the coming years.
byrsch1949 is offline
