Whats the best way to remove surface rust????? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-09-2005, 01:49 PM Thread Starter
Jason Lap's Avatar
Date registered: Sep 2005
Vehicle: 1986 Mercedes 560SEL
Send a message via MSN to Jason Lap Send a message via Yahoo to Jason Lap
I have a 1986 560-SEL ,I kept it in a heated garage..
The rust is surface rust,it is not body rot. It is so tiny you would not see it unless I pointed it out to you. I never drove the Mercedes in the winter,or during bad weather,i have a cheap Honda accord for bad weather.
I drove it to a local Autobody shop and he insisted buying a brand new fender,He said he can find a good after market one.He does not wast time fixing surface rust,money is not made that way in hid shop.
He told me that anyone offering to fix my fender would be robbing me blind.
He clains its not possible to fit surface rot,it will
always come back to haunt you.Plus its completely impossible to match the color of an origional paint job.
I am upset becuse this is the only blemish on the car,its been kept in a heated garage in Greenwich,Connecticut,I purchased it because the origional primer on the frame and undercarraige are in mint condition,Plus it has the origional paint job.
Cananyone point me in the right direction toa autobody shop that can fix up a small area and prevent the rust from returning?
Years ago I saw a tv show on autobody were they kill rust dead in their tracks,I am not sure what procedure that is used but it stops rust dead in its tracks,maybe somw one reading this might know how its done.I just hope I can find a Professional bodyshop in the Connecticut area that handles small jobs like this.
I am in Connecticut arrea ,but will drive to surronding states if necessary.
I will inclose a picture of the front left fender
Thanks for your help Jason
Email nikonls8000@comcast.net
Jason
1986 560SEL
pictures http://community.webshots.com/album/452493168fpzzyq
Jason Lap is offline
post #2 of 6 (permalink) Old 11-09-2005, 06:16 PM
BILLSONG's Avatar
Vehicle: 03 ML500, 94 CADILLAC DEVILLE CONCOURS, 350ZR
RE: Whats the best way to remove surface rust?????
If he insisted you to get a brand new fender and it is not possible to match the color then that mean that he will get a fender that is pre paint to the original color. I believe that a brand new fender will come in only primer and paint to match your car. Remeber when it come to automobile you have to check other place.
IMO he is lazy for a small job. What would be easier sand down, bondo, and paint or R/R and paint?
BILLSONG is offline
post #3 of 6 (permalink) Old 11-09-2005, 06:34 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Jason,
While I don't know about that particular bodyman doing it, I agree that the fender should be replaced. That is a pretty bad rust spot. It will come back more than likely. Fortunately, W126 fenders aren't as pricey as some other things.
Ike
flyboyike is offline
post #4 of 6 (permalink) Old 11-09-2005, 08:20 PM
Premium Member
roncor's Avatar
Date registered: Jan 2005
Vehicle: '91 420 SEL, '80 240D, '87 560 SL, '93 190E Sportline, '70 300 SEL 6.3
Quoted: 41 Post(s)
Premium Member
Jason, The problem, one that the body man all too well knows, is that it's not just surface rust! Wait until you see what's underneath! The way to remove this cancer is to disassemble, grind out all the rust area, then repair it as required. Your fender looks like it can be saved.
With regards to paint, it should be no problem to match. Local professional body shops can match even older paints. Then they blend into the surrounding areas so you won't see a drastic change from one panel to another. Find a repair shop that will explain all the procedures to you. My rough estimate is $300 to $500. And no, there is no miracle product for rust in that area. There are products that eliminate rust, but it just doesn't apply here.
Check out these pics of "surface rust" at the bottom of the driver's door. Then, look at the bottom of the door when it was removed! Best of luck, it will be worth fixing!
If you want to see a real horror show, check out my restoration pics in my "gallery"!
Roncor
'80 240D, '87 560SL, '93 190E Sportline, '91 420SEL, '70 300SEL 6.3
roncor is offline
post #5 of 6 (permalink) Old 11-11-2005, 03:35 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
A good bodyman can take out the rust, it can be sand blasted, filled and made to look great. Will the rust come back, maybe if it is not properly done, they restore classic cars with lots of rust. The paint can be matched including fading. I just had some spots done on my 92 and you cant tell, pricey yes, but imposible to tell. If they want to change the entire fender there is more damage by doing that, even rust thru, a patch can be welded in.
Peter Guenther is offline
post #6 of 6 (permalink) Old 11-12-2005, 09:09 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 10 Post(s)
Rust is something you can never ever do in a half -a** way. If every speck of it isn't removed, it will come back -- later if not sooner.
Your rust is on a seam line where two pieces come together. They have to be seperated, sandblasted to clean metal, treated, primed and painted. Anything less is a complete waste of money.
I suspect your body guy was thinking if he pulled the fender off to clean the rust -- what's better spending the money to clean up an old fender or spend the money on a new one? As pointed out, 126 fenders aren't that expensive so why screw around? If the dollars are close go for the new and be rid of the rust on that piece of sheetmetal.
It just takes a few drives on a salty road without a rigorous cleanup afterwards to get rust started. The warm garage can actually contribute to it if the car is wet because the warmer moisture will attack the metal faster than ice. Frequently there is a tiny pit or scratch - barely visible that the water and salt start on.
Paint is easy to match - shouldn't be an issue.
A rust spot that size, to me, isn't tiny -- it's the tip of an iceberg.
Just remember - rust never sleeps.
sfalkenberg likes this.
Mike
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline
