WINDOWS WILL NOT GO DOWN ON '87 300TD - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-07-2005, 02:28 PM Thread Starter
HUD
Date registered: Nov 2005
None of the windows will work on my '87 300TD. I have replaced the lock-out switch and the fuses. Nothing helps. Any suggestions? I am desperate!!!!
HUD is offline
post #2 of 6 (permalink) Old 11-07-2005, 02:37 PM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
RE: WINDOWS WILL NOT GO DOWN ON '87 300TD
try checking the power windows relay
benzboyz is offline
post #3 of 6 (permalink) Old 11-07-2005, 03:09 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
benzboyz - 11/7/2005 4:37 PM
Good idea.
flyboyike is offline
post #4 of 6 (permalink) Old 11-11-2005, 06:51 PM Thread Starter
HUD
Thanks for the suggestion. Where is the relay located?
HUD is offline
post #5 of 6 (permalink) Old 11-12-2005, 04:41 AM
Ben J Men's Avatar
Date registered: May 2005
Vehicle: 88 560sl, 87 300E
If it is like the 300E the relays should be right behind your fuses in the engine compartment, just unscrew the lid behind it. Don't just check the fuses, replace them. On mine they looked fine and when I pulled them out they fell apart. Also, I bought one relay at the dealer for $28.00 and just keep pulling one relay at a time till I found the bad one. Parts mgr. and I did it right in the parking lot. Worth the time we found 3 that weren't working, before I got there I thought I had an electrical nightmare.
Good Luck
Ben J Men is offline
post #6 of 6 (permalink) Old 11-28-2005, 02:38 PM
In my 300CD the problem was window lifters, for which I got a quote of around $300.
fishfry is offline
