Combo switch- can I fix it? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-21-2005, 01:13 PM Thread Starter
Date registered: Oct 2005
My 82 300td wagon wipers,cruise control, and hi beam flashers are all fluky. I suspect the switch is cruddy inside. Has anyone taken it apart and cleaned it up?
82dieselwagon is offline
post #2 of 2 (permalink) Old 10-24-2005, 05:44 AM
MBL87560SEC's Avatar
Date registered: Jul 2004
Vehicle: 1987 560SEC Now 145K mi. (Summer 2016)
Quoted: 139 Post(s)
RE: Combo switch- can I fix it?
After all the work to remove the switch, disassemble, clean/repair, reassemble, reinstall switch...... Wouldn't it be too bad if, after that, you found you couldn't repair it.......? Or perhaps even find yourself unable to drive the car do to some little switch phramus that went sproing or broke during the switchectomy?
A replacement new switch isn't too, too expensive, and considering the critical safety items governed by it (wiper, hi - low beam control, turn signals + speed control) I'd be inclined to replace it. After all, it is more than 20 years old and seen a lot of use.
At least I'd know I did the best repair possible by replacing the switch.
MBL
MBL87560SEC is offline
