Heater problem, 1989, 260E, - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-12-2005, 06:28 PM Thread Starter
Vehicle: Benz 260E and others
The weather is turning cool and I now need to use the heater in the morning.
The problem started last year but I completely forgot about it during the summer months.
I can't get heat in the car, even with a fully warmed engine and the temperature control set at Max heat...(either on Econ or a/c)
The heater will give heat immediately after I floored the accelerator for a few seconds as if it needed nearly 0 vacuum to operate properly.
Is the water valve vacuum operated?
Thanks for you help
1989 260E
2006 Mazda 5
1978 Corvette
1974 MGB
1998 Southwind Motorhome
1996 John Deer lawn mower tractor.
Jackd is offline
post #2 of 2 (permalink) Old 10-13-2005, 05:45 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 8 Post(s)
RE: Heater problem, 1989, 260E,
Check for air in the cooling system.
Good luck.
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline
