Horrible Fuel Consumption Reasons? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-10-2005, 03:18 AM Thread Starter
ozgurgoral's Avatar
Date registered: Oct 2005
Vehicle: C200K Sports Coupe
C200 Kompressor Coupe year 2001. 80.000km.
Can you experienced people write your opinions about what can cause too much fuel consumption?
"It's like 20-25l/100km (10mpg maybe)"
Spark Plugs
Fuel Filter
Air Filter
02 Sensor
all checked. No problem found. What should we check more?
Thanks in advance.
Ozgur
ozgurgoral is offline
post #2 of 10 (permalink) Old 10-10-2005, 03:26 AM
~BANNED~
deathrattle's Avatar
Date registered: Jan 2005
Vehicle: 1992 W126 300 SE
Quoted: 2 Post(s)
RE: Horrible Fuel Consumption Reasons?
Are you wearing your Dad's shoes by mistake?[:D]
deathrattle is offline
post #3 of 10 (permalink) Old 10-10-2005, 03:48 AM Thread Starter
ozgurgoral's Avatar
well, they're 225 in front, and 245 on back. But does it affect the consumption that much?
Ozgur
post #4 of 10 (permalink) Old 10-13-2005, 06:56 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 9 Post(s)
Have a mechanic with a computer connection check for failure codes.
Your Mass Air Sensor / 02 sensors / Throttle Position sensor or even temperature sensors may be causing the mixture to run very rich.
It can run fine this way - with the horrible consumption of fuel.
Good luck.
Mike
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline
post #5 of 10 (permalink) Old 10-20-2005, 12:25 AM Thread Starter
ozgurgoral's Avatar
My concern is that, there are no errors in the computer at my mechanics, everything seems in the correct ranges. Do you think something invisible is causing it? MAS and 02 sensor seems fine.
First of all I'm doing short trips from work to home, takes 15 minutes maximum each trip. Till the motor gets warm, consumption must be higher, isn't it. (the outside temp is around 8-9 degrees in the mornings these days.
Second, my tires are 225 front, 245 rear.
Third, there's a dense traffic, and I checked my average speed is not more than 25km/h. Can it be effective also?
So under these circumstances, do you think it's normal to consume that much? (around 18 litres/100km or around 13mpg)
Thanks in advance again.
Ozgur Goral
post #6 of 10 (permalink) Old 10-20-2005, 12:30 AM
Date registered: Apr 2005
Vehicle: CLK430
Send a message via AIM to sicrx65
10 MPG with a C200K? I do think there is something wrong, or it might be because of a heavy foot? That is around how much I get with my CLK430.. and I have a lead foot...
PS I have 19 inch rims with 235's in the front and 265's in the rear.
sicrx65 is offline
post #7 of 10 (permalink) Old 10-20-2005, 01:29 AM Thread Starter
ozgurgoral's Avatar
I don't know but it's really annoying. I'm working on this issue for 3 weeks. The computer shows everything as ok. No faults. And I'm really tired of it.
Ozgur
post #8 of 10 (permalink) Old 10-20-2005, 08:41 PM
Date registered: Jul 2005
Quoted: 1008 Post(s)
Check for any cracks in the air intake tube. I saw this on one that was getting the same rotten mileage you are. New tube and well over 20 mpg again. The car did not log a code.
Noodles is offline
post #9 of 10 (permalink) Old 10-21-2005, 01:50 AM Thread Starter
ozgurgoral's Avatar
Ok I'll check that this evening with my mechanics. Anything else to check on your mind? Thanks very much by the way. I hope it has cracks and this nightmare will be over then. :)
post #10 of 10 (permalink) Old 10-23-2005, 07:15 PM
It really sounds like an air intake leak before the MAS. If it is not that I will do some digging around, This should not be a tough problem to trace, but one never knows.
Can you or your mechanic hook it up to a diagnostic computer while it is running? It will show you all the values that each sensor is sending to the ECU. I would bet one of the sensors is way out of range. And once in awhile for whatever reason they do not log a code. That sensor could be the key to this issue.
Noodles is offline
