Replace Waterpump on 1989 300E - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-03-2005, 02:39 PM Thread Starter
Date registered: Oct 2005
I need to put a new water pump on this car. Is there a manual I get get a hold of. Does anyone have any suggestions. Is it true you have to take of the power stearing unit to get to it?? Thanks. All suggestions appreciated.
preston32[:D]
preston32 is offline
post #2 of 5 (permalink) Old 10-19-2005, 05:02 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 10 Post(s)
RE: Replace Waterpump on 1989 300E
In general, it is not a difficult job with the right tools.
General Directions;
- Remove radiator hoses - capture old coolant
- Remove trans cooler lines and plug with stopper
- Pull shroud,it twists off after unclipping.
- Pull radiator - absurdly easy - 4 bolts or screws
- Remove clutch fan assembly
- Loosen belt
- Remove pump assembly. Check the design. I had a W123 with an impeller assembly you can pull from the center of the pump housing and avoid a complete pump replacement.
Here's a link at mercedes shop, but honestly, he makes it look harder than it is....
124 radiator removal ( this is first)
http://www.*****************/Wikka/W124Radiator
117 water pump job ( harder than the 124 due to distributor interference)
http://www.*****************/Wikka/M117WaterPump
Good luck
Mike
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Too much of anything is bad, but too much of good scotch is barely enough."
(Mark Twain)
mjhawkins2346 is offline
post #3 of 5 (permalink) Old 10-20-2005, 06:05 AM
Date registered: Jan 2004
Quoted: 34 Post(s)
Don't use an aftermarket pump. Get a rebuilt from the dealer.
Len
sokoloff is offline
post #4 of 5 (permalink) Old 03-03-2011, 12:14 PM
Date registered: Mar 2009
two different gaskets
Hi guys,
Do you happen to know why M/B gives you two gaskets in the box for the SLK320 reman water pump? The car uses a thin rubber ribbon gasket from the factory and the box contains this very gasket and then a flat metal gasket coated with a black sealer. This car is a 2001. I am wondering if the older versions used a flat surface thus requiring the flat gasket.
Thanks,
Mark
scooterB is offline
post #5 of 5 (permalink) Old 03-03-2011, 05:07 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
^you are posting on the wrong thread man
R170 SLK Class - Benzworld.org - Mercedes-Benz Discussion Forum
1984babybenz is offline
