Under warranty &NO OIL in engine!! What to expect? - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 10-02-2005, 10:03 AM Thread Starter
Date registered: Feb 2004
Vehicle: SL320, 300e, 450SL
A friend of mine is traveling to Texas from Mn this weekend and his cars (01 E-class) oil light came on
and the car suddenly stopped on the freeway in Illinois. The car is still under extended warranty and the 40K service including oil change was just performed at the dealer a few hundred miles ago. He popped the hood, and to his surprise, no oil reading on the stick...BONE DRY!! No indicators of an oil leak and they were using conventional oil apparently. I had suspected the dealer forgot to fill it with oil. Is he at all liable for this in your estimation? Strange that 8-9 quarts of oil is missing less than 1k miles after a major service interval. I told him id post here and ask all of you for your thoughts and experiences!! THANK YOU for your advise, BC
bc2885 is offline
post #2 of 14 (permalink) Old 10-02-2005, 02:09 PM
asianml's Avatar
Date registered: Sep 2005
RE: Under warranty &NO OIL in engine!! What to expect?
That's just messed up. If any damage happpens to the engine the dealer should foot the bill. He is in no way liable for that. How can you forget to add oil after draining it? What dealership was it?
asianml is offline
post #3 of 14 (permalink) Old 10-02-2005, 03:14 PM
MarcusF's Avatar
Date registered: Apr 2005
Vehicle: 2002 CLK430
As an ex-wrench, I can tell you if the engine seized due to a lack of oil, it may be a complete write off. Being expensive to replace under warrantee, the technicians will determine the cause of failure. That is, as long as the owner has the car towed to a dealership as is. I believe the oil either leaked or burned. Leaks are obvious and if 8 quarts of oil is burned over a short period of time, the catalytic converters will show it (toast). I find it highly unlikely that someone forgot to put any oil in the car after an oil change. The engine would have spun a bearing long before the first hundred miles. I’m unclear why a dealer would use conventional motor oil rather than synthetic. It’s also a mystery why the oil pressure sensor failed. I would strongly advise that no one add any oil before the car is dropped off. Any factory mechanic can tell when an engine dies due to a lack of oil (spun bearings are hard to miss). They can also tell if an oil pump still works. A working oil pump with a functioning pickup tube, with an oil filter that’s not clogged, combined with every bearing in the block showing signs of running dry, and oil in the sump, usually points to fraud. If they don’t find oil in the sump, they may look into whether the pressure sensor failed. If they find oil they may be more interested in why someone tried to cover up what really happened.
The good news is, in about a week your friend will have a new factory engine.
MarcusF is offline
post #4 of 14 (permalink) Old 10-02-2005, 07:42 PM
samhmbz's Avatar
Date registered: Oct 2004
Vehicle: 164.125 163.175 Previous W211MOPF-W211C209W202W124
What kind of warranty ? have seen aftermarket warranty companies supply junk yard engines..........
Sam
Free maintenance ? buy a Bimmer......
samhmbz is offline
post #5 of 14 (permalink) Old 10-02-2005, 08:21 PM Thread Starter
Factory extended warranty. Please read the first post.
I told him to buy a new aftermarket type warranty after factory one expires in 10/07.[:0]
bc2885 is offline
post #6 of 14 (permalink) Old 10-02-2005, 09:19 PM
samhmbz's Avatar
bc2885 - 10/2/2005 8:21 PM
Well now that I know its factory warranty(not stated in the other post I did read it...)
I agree the insp. procedure will go the way MarcusF
states. Best of luck with it.
Sam[:)]
samhmbz is offline
post #7 of 14 (permalink) Old 10-03-2005, 08:52 AM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
If he is in Chicagoland - best bet to get it to Barrington Motorwerks. Did he call 1800-for-MERC ?
Kirill
Kirill is offline
post #8 of 14 (permalink) Old 10-04-2005, 10:27 AM
"I’m unclear why a dealer would use conventional motor oil rather than synthetic."
Because they're crooks...
My dealer (PS in Seattle) used regular oil in my 2000 CLK and charged me for Mobil1 (which I requested) for my first servicing. The second servicing they again used regular oil (for which they were reimbursed by MBUSA). I didn't discover this until after my third service while investigating another service issue.
doctore is offline
post #9 of 14 (permalink) Old 10-04-2005, 04:14 PM Thread Starter
doctore - 10/4/2005 12:27 PM
Hummmm..."Why a dealer would use conventional"
Probably because it really doesn't much matter what you use. The only reason dealers use full synthetic in their factory warranty cars is to not have to use up valuable billable hours from their techs as synthetics have twice the shelf life or more than conventional.I use a mixture of both in all my vehicles. Thank God for Amsoil!
bc2885 is offline
post #10 of 14 (permalink) Old 10-05-2005, 09:48 AM
olivengco's Avatar
Vehicle: 2000 E320
doctore - 10/4/2005 10:27 AM
Just curious and this may sound like a dumb question. How can you guys tell whether it's conventional oil or synthetic that they put in your car? I couldn't tell just by looking at the oil, is there a way to examine the two types of oil?
olivengco is offline
