Misfire/Rough Idle 97 S420 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-28-2005, 02:13 PM Thread Starter
Date registered: Nov 2003
Vehicle: 1998 C280 Sport, 2009 GL 320
I have a 1997 S420 with 133k miles, it has developed an engine shake that is visible when you look at the engine when the engine is running. The Check Engine light is not on. There does not seem to be any loss of power. The stealer told me they don't know what it is but for 99.75 per hour plus parts they would find the problem.
Any suggestion would be greatly appreciated.
kxmills is offline
post #2 of 6 (permalink) Old 10-05-2005, 04:08 PM
m.reno's Avatar
Date registered: Jun 2005
RE: Misfire/Rough Idle 97 S420
hi, im not a mechanic, however handy. my e420, will easily throw a code if there is a issue, check yours first. go to autozone, and utilize theuir scaning tool for free, just drop down a credit x=card for collateral, no charge occrs, it is free.
2. spark plug wires , grounding, or bad plug or cat converter going out ! good luck
m.reno is offline
post #3 of 6 (permalink) Old 01-12-2006, 01:22 PM
areces.cf's Avatar
Date registered: Sep 2004
Vehicle: Mercedes W140 500SE, W126 560SEL & W460 300GD
I have the same problem on my 90テつエs 560SEL, Iテつエve tried everything, but I didnテつエt find the solution, so if you do it, please tell me.
Thank you and good luck
areces.cf is offline
post #4 of 6 (permalink) Old 01-13-2006, 08:37 PM
Date registered: Aug 2005
Have you looked at the wiring harness? I know for a fact on most 97 +/- a year or two the harness seems "fall apart". If you see any bare wires you may need to replace the engine bay harness.
Kenneth
A_500_Guy is offline
post #5 of 6 (permalink) Old 01-14-2006, 06:03 AM
donniebhoy's Avatar
Date registered: Jan 2006
areces.cf - 1/12/2006 4:22 PM
CEL doesn't appear? could be the engine mountings.
donniebhoy is offline
post #6 of 6 (permalink) Old 01-27-2006, 12:22 PM
areces.cf's Avatar
I've changed, spark plugs, wires, distributor and rotor, inyectors, filters, and check CO2 ratio, and nothing. The engine mountings are new.
