J-tube blocked / valve cover and oil pan pressurized - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-20-2005, 11:40 AM Thread Starter
Date registered: Aug 2005
OK, I've nearly toubleshot my 103 to the point of reasonable oil consumption. Just a simple queston: Why would a prior owner plug the J-tube that vents the valve cover to the intake manifold? The car has no PCV valve. Compression is consistant at 155psi across all cylinders. Car does not smoke disproportionatly at start up so I do not suspect stem seals.
1990 300TE
1978 280CE
1972 250C
johnevans is offline
