Antenna Help - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-06-2005, 02:20 PM Thread Starter
Date registered: Sep 2005
Antenna Help
Hey i new i just wanted you all seem like you know a lot about benzs i wanted to know if any one knows how to remove an antenna. The car i have is a 190e 2.6 made in 1991
Thanks for the help guys
TopDog324 is offline
post #2 of 5 (permalink) Old 09-06-2005, 02:41 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
RE: Antenna Help
TopDog324 - 9/6/2005 3:20 PM
Post your question in the W201 forum, they'll help you out.
flyboyike is offline
post #3 of 5 (permalink) Old 09-06-2005, 03:34 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
RE: Antenna Help
Naw, all models are the same.
Remove the trim nut at the top of the antenna base.
Then with motor attempting to raise the antenna, just pull it out. Pull hard.
This is the "mast" which is likely your problem.
Note: a lot of antenna problems can be solved by raising/lowering antenna several time while lubricating it with WD-40, etc. But, if it's bent or the cable is broken, mast replacement is required.
Just looking at it once removed will give you an idea how it works. Inspect to see if nylon cable is broken. If it is, you'll likely have to open the motor case to fish out the pieces.
A new mast is $30-$50. Your dealer will have them because they get replaced often. Perhaps you can compare your nylon cable length with a new one at dealer.
Insert nylon cable into guide tube and set antenna to retract (turn off radio, etc.) It may take a couple tries to determine how deep to insert the cable and which way to turn the teeth.
If the motor doesn't work, you'll have to remove the entire unit. It's obvious how, although there may be trunk lining to remove to get to it.
lkchris is offline
post #4 of 5 (permalink) Old 09-06-2005, 04:09 PM
majorkahuna's Avatar
Date registered: Jun 2005
Vehicle: SL320/ML320
RE: Antenna Help
The easiest way to remove your antenna is to park in a bad neighborhood for a couple of hours.
majorkahuna is offline
post #5 of 5 (permalink) Old 09-08-2005, 06:58 AM
Date registered: Apr 2005
Vehicle: CLK 350
RE: Antenna Help
haha
that was cool
[:D]
cesarillo is offline
