Need help with my ML320 - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-27-2005, 03:52 PM Thread Starter
Date registered: Aug 2005
I have 2 reoccuring codes
po 170
po 173
left and right adaptive reached their limit
ANy common cause for these 2 codes?
I would believe something is causing either a steady rich or steady lean condition.
Changed the reg filter assembly as it seemed as though fuel was leaking thru the vacuum port,But after 2 drive cycles,THe codes are back
Thanks in advance for any help
Otto
Otto J is offline
post #2 of 7 (permalink) Old 08-27-2005, 05:14 PM
samhmbz's Avatar
Date registered: Oct 2004
Vehicle: 164.125 163.175 Previous W211MOPF-W211C209W202W124
RE: Need help with my ML320
maybe a vacuum leak around the air intake pipe or faulty air mass sensor............
sam
samhmbz is offline
post #3 of 7 (permalink) Old 08-27-2005, 05:16 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 207 Post(s)
The codes are for Mass Air Flow Sensor. It is located inline right after your air filter and before the intake. About a 5 minute DIY repair. You may possibly be able to clean it with a good throttle body cleaner. This is usually a temporary fix and the codes will usually come back.
For specific ML 320 problems in the future, you may be more sucessful posting in the W163 Forum.
Welcome to Benzworld!![:)]
cmitch is offline
post #4 of 7 (permalink) Old 08-28-2005, 08:51 PM
Buy the maf sensor and the problem will be fixed. The maf is as common as a cold. This is the weakest electrical component Benz has. Good luck. You may need somebody to reset self-adaptation for the fuel mixture.
LhaitzSS is offline
post #5 of 7 (permalink) Old 08-29-2005, 05:02 PM Thread Starter
CHanged it today, local store 298, Benz dealer 219
Installed and drove it for 30 minutes problem solved
The long term fuel trims were buried at 34.5% while driving with my scanner the last 2 days after iput the new one in, I drove it and watched the long term trims steadily lower the farther i drove and leveled off as about 3-7%.
THanks for the help,I had cleaned it before but not so easy to get inside
THis problem also caused a slightly weird acting trans,Which is now cured also
Otto J is offline
post #6 of 7 (permalink) Old 02-21-2010, 07:39 PM
Date registered: May 2008
Hello, some one can help me with this. I change my MAF from a ml 320, but the new one works worst than the older one.
Do I need any specific steps for change it?
THNAKS
lucianosegura is offline
post #7 of 7 (permalink) Old 02-21-2010, 08:10 PM
Kajtek1's Avatar
Quoted: 1163 Post(s)
Is it original Bosh MAF?
Kajtek1 is offline
