Need to remove radio to get serial # - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-21-2005, 04:35 PM Thread Starter
Date registered: Aug 2005
Needed to disconnect the battery to "re-set" the CD changer and the code that I got from the MB dealer is not the correct code. From reading some posts, it appears that I need to get the serial # from the radio its self to get the correct code. How do I do this?[?]
littlesusie32 is offline
post #2 of 2 (permalink) Old 08-23-2005, 12:21 AM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
RE: Need to remove radio to get serial #
you mist remove the radio itself and check the serial number stamp on the radio. then maybe you can compare the serial number the dealer gave you, if its the same and still cannot accept the code correctly, it might be the radio itself has a problem. BTW what type of vehicle do you have so that I can help you on how to remove the radio properly?
benzboyz is offline
