W124 E320 Coupe 1994 Quad Exhaust in the City of London - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-10-2005, 03:02 PM Thread Starter
m6dtt's Avatar
Date registered: Aug 2005
Vehicle: W124 E320 Coupe Auto
Send a message via Skype™ to m6dtt
Hi
I have a standard car with the 195x65x15's on it. I want to have at least 235's but I seem to get conflicting advice on if I can or can't. Is 225 really the max or can I go for is 235's. I don't want to drop the susp, nor flare the arches, nor have different tyres front and back. I definitely don't want the tyres rubbing. Has anybody got 235's on a W124? If so pls let me know. Many thanks.
m6dtt is offline
post #2 of 2 (permalink) Old 08-11-2005, 12:14 AM
Storm's Avatar
Date registered: Jan 2004
RE: W124 E320 Coupe 1994 Quad Exhaust in the City of London
OEM is 195/65R15 (634mm diameter), you'd have to have 235/55R15 tyres (640mm Diameter = 0.95% larger).
Should be ok, but it depends how wide your rims is. I would not advise you to fit 235's on a 6 inch wide rim. If your rim is 7inch wide you should just be ok, 7.5inch and above and the setup will be perfect.
Storm is offline
