Gasoline - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-06-2005, 02:43 PM Thread Starter
Date registered: Jul 2005
Gasoline
Hi Benz friends, II bought 6 month ago a 190 E 230 (1984) with 2000000.00 miles on it. I live in California. And I was just wondering what kind of gas I should use?
I get so many different answers from friends. And since the rising gas prices I was just wondering if it is okay to get the cheapest fuel? The guy that sold the car to me said I always should put the highest grade in otherwise it will ruin the engine. I had told him that I put the lowest grade (I think it's 88?) and didn't hear any ping from the engine and no performance difference, but my friend still insists that I should put 92 grade in otherwise it will ruin the engine because the car is so old. Is that right. Any help would be appreciated. Thank you Volker from Hollywood.
volkerusa is offline
post #2 of 3 (permalink) Old 08-06-2005, 03:09 PM
mdvijay's Avatar
Date registered: Apr 2005
Vehicle: 03SL55AMG,2008 F430spider
RE: Gasoline
MB cars usually takes premium octane gasoline. check your fuel filler door it must be written what grade to use and once again welcome aboard
mdvijay is offline
post #3 of 3 (permalink) Old 08-07-2005, 01:07 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 10 Post(s)
RE: Gasoline
That car expects premium. If you put low octane it will try to retart the spark sufficiently to avoid predetonation. Your power will suffer and the engine will run hot - hopefully not too hot or that will end all of this in a hurry.
The moral of the story is that 10 cents per gallon savings is not the saving you want or need.
Buy your gas at Costco and you will pay less for your premium -- probably less than a lot of regular stations.
Good luck.
Mike
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline
