D2R bulbs Vs. D2S bulbs - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-19-2005, 11:39 AM Thread Starter
Thaden25's Avatar
Date registered: Nov 2004
Vehicle: ML55 ////AMG/CLK320 Cabriolet/GL450
Send a message via Yahoo to Thaden25
Hi! I have ML 55, 2000 with OEM Xenon. My light bulbs start to wear out, so I'm looking for a new pair of light bulbs. I think I need D2R bulbs, but I wonder if I could use D2S bulbs instead, since It is kind of hard to find Philips D2R bulbs with 4300k.
Is it okay to use D2S bulbs?
Where can I get those light bulbs? (Already check on ebay)
Thank in advance.
Thaden25 is offline
post #2 of 3 (permalink) Old 07-19-2005, 01:31 PM
n5160u's Avatar
Date registered: Apr 2004
Vehicle: 2000 Designo SLK-05 C230WK-05 E320CDi-2010 GLK 350
RE: D2R bulbs Vs. D2S bulbs
Both lamps have the same brightness BUT the focal point of the light source is different. One lamp is set up for projector beam fixtures including Bi-Xenon types, and the other type set up for reflector type headlights like the first generation ML's had. They do not interchange.
This place sells different lamps but I am not sure if the lamps meet DOT MOT or TUV specs.
http://www.xtralights.com/index.asp?PageAction=VIEWCATS&Category=5&smc=11218 04895985
Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid, Hi-Definition Progressive Scan Wiper Blades.
Law-makers are supposed to regulate in the interest of the public as opposed to regulating in the interest of the regulated party.
If it says Pratt and Whitney on the outside it better say Martin Baker on the inside.
n5160u is offline
post #3 of 3 (permalink) Old 07-20-2005, 06:09 AM
MLOffRoad's Avatar
Date registered: Feb 2005
Vehicle: Mercedes "M32"
For the older style reflector Xenons on your ML you need to use the D2R (Reflector) and not the D2S (Projector) bulbs. This will produce the proper beam pattern and not have light shining where it should'nt. You can easily find D2R replacement bulbs for your ML by searching Google for them.
SOLD!285-75-16 (33.1") BFG Mud-Terrains, Black Powdercoated Wheels, ORC Lift Kit, H&R 1" Wheel Spacers all-around, Paintmatched Bumpers, Flares & Clading, Updated Headlights, 6000K Xtec HID's, Silverstar Blinkers, WAAG Full Front Brushguard, Custom Fabricated Winch Mount, Warn XD9000i, 16500# MasterPull Synthetic Cable, PIAA Pencil-Beam 580's, 5% + 15% Tint All Around & 30% down the windshield, Custom Magnaflow Exhaust, K&N Drop-In. SOLD!
MLOffRoad is offline
