Error codes PO170 & PO173 - ? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-19-2005, 12:38 PM Thread Starter
Date registered: Jul 2005
Send a message via Yahoo to Dadaman
What exactly are these error codes - Can I fix myself - What is required to fix. Moderate mechanic
Dadaman is offline
post #2 of 9 (permalink) Old 07-19-2005, 01:05 PM
gzt
gzt's Avatar
Date registered: Jun 2005
Vehicle: ML320, S430
RE: Error codes PO170 & PO173 - ?
I do not have access to the exact MB codes at this time but here are, as a general idea few findings:
P - Powertrain
0 - generic
1 - Emission management
73 - Fuel Trim Malfunction (Bank 1)
the P0173 might be: Fuel Trim Malfunction (Bank 2)
the info is taken from
http://www.obd-codes.com/trouble_codes/index.php
interesting reading.
Greg
'82 300TD, '87 300SDL, '87 190E,
'95 S320, '00 S430, '01 ML320, '06 S500
gzt is offline
post #3 of 9 (permalink) Old 07-19-2005, 06:58 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 210 Post(s)
Mass Air Flow Sensor. The codes on my ML were the same for MAF.
cmitch is offline
post #4 of 9 (permalink) Old 07-24-2005, 07:31 AM Thread Starter
Thank you all. I did cave and go to the dealer. Hot dang that Starmark is a fine thing! MAF tested fine - Mechanic found a broken hose, replaced it, MAF sensor failed.[xx(]
All was well after it was replaced. Went to drive away from the dealer (O out of pocket except the $11 hose and $90 hourly rate [V]
Did not start - They gave me a free loaner, kept it and replaced the crankcase angle? sensor.
I start, I drive, all is good[:D]
Bob in service at Coggins Automall is an excellent Mercedes rep and a decent person to boot. If ever i the area and in need of Mercedes help - He is good, straight and honest.
The help I got on this forum helped me save hundreds in "Start from scratch" diagnostic fees I would have paid had I not told the mechanic where to start.
Thank you!
Dadaman is offline
post #5 of 9 (permalink) Old 01-13-2011, 02:28 PM
Date registered: Jan 2011
I have a 2003 ML 350 which the battery was completly dead for 3 weeks and I uased a trickle charger to charge the battery and now there is numerous codes like P0270, C1020, C1045,C1026,C1046 and this shop has had the SUV for a week and does not know what is wrong with it. Any help would be appreciated.
Thanks,
Swordfisher is offline
post #6 of 9 (permalink) Old 04-19-2011, 03:58 PM
Date registered: Apr 2011
Vehicle: 2007 C230 Sport
Send a message via MSN to Lincstr58
Cool OBD code 0170-0173
I have those codes also. its the first issue I have had with this vehicle. the car went to work and 4v hrs later would not start...turn over fine but no fire. I put the code reader on it and these codes came up...i put a fuel pressure tester on the test valve and the vehicle started up and is running normally but still has the error codes...i have the CPS to replace but am waiting and there doesn't seem to be a consensus on the fix. MAFS, CPS, Fuel pump...where to go?
Lincstr58 is offline
post #7 of 9 (permalink) Old 04-20-2011, 07:26 AM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Codes: PO270 = Cylinder 4 Injector Circuit Low; C1025 = CAN Communication BAS Commun ication with ESP control unit faulty . . .
Sorry, I got to run and my info gathering key is not handy, maybe Greg-210 or Germantown can help you further.
JoeVal is offline
post #8 of 9 (permalink) Old 04-22-2011, 01:36 PM
~BANNED~
It depends on what error code is giving. Check the manual about the error code. Then you can decide that you should do it yourself or not.
charleshank1 is offline
post #9 of 9 (permalink) Old 04-22-2011, 02:27 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Generally speaking, the *best* thing to do is to get out of the "general" forum and scroll down the forums page until you see the specific forum for YOUR car (or truck). Then search/post in that forum. This one is for generic stuff arguably applicable to all benz, or of interest to benz owners generally.
Good respective luck to all.
Check Codes is offline
