Electromagnetic cooling fan problem - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-11-2005, 11:17 PM Thread Starter
Date registered: Jun 2005
Grisette is offline
post #2 of 6 (permalink) Old 07-11-2005, 11:19 PM Thread Starter
RE: Electromagnetic cooling fan problem
No answer for my problem about a 190 D cooling fan which refuses to clutch in? Do I have to change the entire fan & clutch?
many thanks
[/QUOTE]
Grisette is offline
post #3 of 6 (permalink) Old 07-13-2005, 08:50 PM
Date registered: Jul 2005
check the sensor on top of the engine ground it see if fan cuts on, you are talking about the fan in front of the water pump right? they rarely have a bad electromagnetic clutch some people wire them to stay on does the aux fan work? car running hot? also check the fuse.
werks is offline
post #4 of 6 (permalink) Old 07-23-2005, 09:50 AM Thread Starter
Thanks for the answer,
I have tried everything even to short out the sensor on the top of the engine with a 2,5 mm copper wire. It dit clutch in a few times, but no more. The engine doesn't run so hot, but I wouldn't take it for a long drive on a hot day.
Fuses are ok.
I got no auxiliary fan.
So I was thinking about getting an auxiliary fan and change it over.
I would prefer to stay with the the original setting.
What do you think? [8D]
Grisette is offline
post #5 of 6 (permalink) Old 07-23-2005, 09:55 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
You probably just need the clutch.
flyboyike is offline
post #6 of 6 (permalink) Old 09-15-2005, 06:40 PM
Date registered: Aug 2005
Vehicle: 1985 300 SD
Hi,
I am just curious; how did you determine that shorting out that sensor would not cause other problems?
Thank and hope you get your problem fixed.
Joe
Grisette - 7/23/2005 10:50 AM
Fuses are ok.
jbleaux is offline
