Freon Recharging - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 07-08-2005, 02:46 PM Thread Starter
Date registered: Jun 2005
Vehicle: 1998 S500
Freon Recharging
Does anyone know anything about freon recharge because i looked at my sight glass and its slightly foaming so i know i need a recharge and my ac is not as cold as it use to be. Can anyone help me how to recharge the freon. I have a 93' 400E. Thanks
lpaddikt is offline
post #2 of 8 (permalink) Old 07-09-2005, 02:27 PM
Date registered: Aug 2003
RE: Freon Recharging
If you are seeing bubbles it is an indication that the freon is low.
Since you system is sealed, you no loger have a good "seal", and that is why the freon is low.
So, you'll need a good A/C shop to first test for leaks, to correct the leaks, and then to recharge your system.
Freon is about $40-$60 per pound. Your system will take 2.5 to 3.0 lbs.
So, this plus labor will give you an idea of cost.
GCalo is offline
post #3 of 8 (permalink) Old 07-09-2005, 02:35 PM
majorkahuna's Avatar
Vehicle: SL320/ML320
Given the cost of Freon, unless you get it in Mexico, it would be a good time to convert to R129. The cost is not more than having to buy recycled Freon.
majorkahuna is offline
post #4 of 8 (permalink) Old 07-09-2005, 02:58 PM
R134 is not a solution for earlier model cars.
R134 is inherently a less efficient medium than is R12, and a system that uses R134 has a larger capacity compressor, evaporator, and condenser.
So, you would be wasting $ to do so.
Have the work done correctly, and the system will funtion the way it was designed to do so.
GCalo is offline
post #5 of 8 (permalink) Old 07-14-2005, 07:10 PM
Date registered: Nov 2004
Vehicle: 94sl-600
I thought the 93 400E already had R-134?
kebowers is offline
post #6 of 8 (permalink) Old 07-14-2005, 08:01 PM
Date registered: Jul 2005
what is r129
juan911sc is offline
post #7 of 8 (permalink) Old 07-15-2005, 12:39 AM
benzboyz's Avatar
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
juan911sc - 7/14/2005 11:01 PM
what is r129
R129 is the SL class roadster of Mercedes
benzboyz is offline
post #8 of 8 (permalink) Old 07-15-2005, 12:44 AM
benzboyz's Avatar
'93 version S400 already has R134a refrigerant. Not unless the charging valves of your A/C system was converted to R12 type which is smaller in diameter.
benzboyz is offline
