» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > General Mercedes-Benz Forums > General Mercedes-Benz
Old 07-06-2005, 07:29 AM   #1 (permalink)
Date registered: Aug 2004
Vehicle: 1995 E320
1995 E320 climate control help
My 1995 E320 climate control just went into an intermittent state where the fans and fan control, and auto control do not work. Then everything turns on and works fine. Then it does not work fine. A/c etc work...just seems like a loose wire or short or what...any help in troubleshooting?????
pblank is offline   Reply With Quote
Old 07-08-2005, 05:54 AM   #2 (permalink)
Vehicle: 1995 E320
RE: 1995 E320 climate control help
Shade Tree Garage in Morristown found a fuse just in front of the main fuse panel that had an intermittent hairline crack in the fuse. The new fuse was $1.50. Labor was more....e-mail me for total cost.
Old 07-08-2005, 06:21 AM   #3 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E, '03 E500
pblank - 7/8/2005 6:54 AM
How is John doing over there at Shadetree? Is he even alive still?
flyboyike is offline   Reply With Quote
Old 07-12-2005, 05:34 PM   #4 (permalink)
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 00 E320
Sounds like a classic case of failure in the Blower Motor Regulator.
You can access the blower - and it's on top of it - under the dash on the passenger side. You loosen the plate and drop it down.
The part costs about $150 and a screwdriver, nut driver and a soldering iron is needed. It has thermal paste and a heat sink. Attach and use the paste carefully.
Autohaus Arizona carries two versions of the part - french and german - pick german if either seems OK.
If you take it to a independent shop - figure on $250 to $300. The dealer more like $400
Good luck
Mike
Now: 2000 E320, Then: 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline   Reply With Quote
