Central locking - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 08-11-2005, 06:08 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
RE: Central locking
oops,
The pump provides presure to lock, vacuum to unlock!
Peter Guenther is offline
post #12 of 15 (permalink) Old 09-05-2005, 07:14 PM
Date registered: Sep 2005
Send a message via MSN to Wayne Mason
RE: Central locking
Hi From New Zealand, My pump is making a noise (motor running) but nothing happens to the door locks. Is there a way to dismantle the unit or is it a sealed unit. (thow away & spend $nz1500 to replace) I assum from the noise the power supply is good although it is very quiet , There was mention of a defective hose how do I get to it ??? Thanks in antisipation
Wayne Mason is offline
post #13 of 15 (permalink) Old 03-17-2006, 08:51 PM
Date registered: Jun 2005
RE: Central locking
Peter::: I have recently developed an issue with mine in that it was working okay on both doors and trunk with keyless remote until I spray lubricated the latch and keyed entry. Now none will work. Any ideas on how to correct the problem. Will I have to disassemble the door / trunk locks??? Or can I clean with a good quality elect cleaner?? Any advise will be appreciated. Thanks Larry
anderson is offline
post #14 of 15 (permalink) Old 03-18-2006, 10:11 AM
RE: Central locking
There are two microswitches in each front door and the trunk, that start the pump, turn it one way and it locks, turn it the other, unlocks. Pressure to unlock /vacuum to lock. Try your trunk, I dont think you sprayed there or the dash switch. Your IR remote acts independently on the pump. If your lumbar does not work the pump is not working. I assume you checked fuses. AS to the previous post there was a MB bulletin that addressed a defective hose inside the pump, that ran from the motor to the manifolds (the little ports)it applied to 95 or so. The pump has safeties that shut it down if it can not attain time /vacuum / pressure, paramaters. I think removing the fuse would reset it. I think it stores codes, but only a reader can retrive them thru the diagnostic connector (the manual says)
post #15 of 15 (permalink) Old 03-18-2006, 10:27 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
RE: Central locking
Rogerthelodger - 7/2/2005 6:16 AM
Can't find a manual anywhere
Look here
http://www.startekinfo.com/StarTek/
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
