Engine missing: E-220, 1996 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-02-2005, 12:56 AM Thread Starter
Date registered: Jul 2005
Send a message via MSN to electrompint Send a message via Yahoo to electrompint
I have a e220, 1996 W124.
somedays back, while driving the temperature rose to the maximum and i saw steam coming out from the bonnet. The mechanic told me that the water pump had leaked. Got it changed... the temperature was back to normal.
But now there is a lot of missing in the engine. The mechanic says that it could be due to damaged gasket or valve. He asked me to add 1/2 litre engine oil to a tank full of petrol and drive for about 200 Kms to see if the problem persists.
No luck so far.
Please suggest what could be the problem.
thanks,
Sumeet Mahajan
India
electrompint is offline
post #2 of 2 (permalink) Old 07-12-2005, 04:57 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 9 Post(s)
RE: Engine missing: E-220, 1996
Sounds like it might have gotten hot enough to cause a head gasket failure - pretty classic symptoms.
The engine is aluminum and very sensitive to overheating.
Have a mechanic you trust check it out.
Good luck.
Mike
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline
