HARMONIC BALANCER RECALL - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-29-2005, 02:32 PM Thread Starter
jtorre1's Avatar
Date registered: Jan 2005
Vehicle: 2007 E350 4MATIC
Send a message via MSN to jtorre1
This message is to inform everyone that I have received a Safety Recall letter from Mercedes Benz. The Safety Recall # 2005-02003, identifies the harmanonic balancer pulley for certain model year 1998 - 2001 vehicles. The Harmonic Balancer pulley on the front of the engine's crankshaft which drives a serpentine belt that powers the alternator, power steering pump, air conditioner and other vehicle accessories. Due to a supplier quality problem the harmonic balancer pulley in certain model year 1998 - 2001 vehicles may, depending upon vehicle use characteristics, be subject to high under-hood temperatures that can, over a long period of time, cause it to deteriorate. Prior to a harmonic balancer pulley deteriorating to a point of affecting vehicle performance and drivability, it will create several different type of driver warnings such as noticeable engine vibrations.
Please check with your local Mercedes Benz dealer and identify that you have a vechile between this year as identified and they will be able to change it and also refund you for the full amount. If you have any problems getting your money back or service please contact Mercedes Benz of USA and they will be happy to assit.
James Torres
1999 E320
2002 325i
1990 325i
James Torres
1999 E430(Lost in Divorce)
2007 E350 4MATIC
jtorre1 is offline
post #2 of 2 (permalink) Old 06-29-2005, 03:32 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
RE: HARMONIC BALANCER RECALL
This has been posted A LOT all over the forum, I did a key points post some time ago:
http://forums.benzworld.org/forums/forums/thread-view.asp?tid=1212149
Check Codes is offline
