1984 300SD .... Problems and I need help. - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 07-11-2005, 08:54 PM
Date registered: Jul 2005
RE: 1984 300SD .... Problems and I need help.
buttercup !!! ok seat is probably wires in the door jam broken from being opened many times , tire wear as with any car get someone that understands good alignment, on the back of the injectin pump is a bolt that can be adjusted to help stop the unsteady idle and a weak spring in it will mean replace it should be about 50 bucks tops. keep her invest in keeping it running right and change oil every 300 rotella T 15-40 oil and a oem filter they are better!!oh and tranny if yours is shifting hard can be adjusted by taking rubber cap off and pulling T out loosen it it gets softer tighten it it gets harder. motor mounts might be bad if you change them make sure no fuel or oil leaks are getting on them.
werks is offline
