Currant draw - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-26-2005, 10:50 AM Thread Starter
jaybro's Avatar
Date registered: Feb 2003
Vehicle: 1999 C-280. & 2000 SL500
Currant draw
What is the typical currant draw of a 1999 C-280
Everything Off???? I have a 4.75 amp draw and that sees hi to me.
jaybro is offline
post #2 of 3 (permalink) Old 06-26-2005, 03:15 PM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
RE: Currant draw
normal current drain if the vehicle is parked and everything's locked and powered down according to MB is more or less 0.02 amps. If you had installed additional accessories the drain might be higher, but from what you haid 4.7 amps you do have a current drain. what you can do is to try to remove the fuse one by one and check if the drain becomes lower, if lower you found the source. but to my experience 0.4-0.8 amps fluctuation on the scale is normal.
benzboyz is offline
post #3 of 3 (permalink) Old 06-26-2005, 04:29 PM
Vehicle: 2005 E320 cdi
RE: Currant draw
That's a pretty big amp draw. Check the alternator and starter for problems.
junkman is offline
