horn - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-24-2005, 10:17 PM Thread Starter
Date registered: Jun 2005
does any one know the horn circuit on a 1983 300tdt. the cheapee manuals dont show the circuit . mu horn doesnt work fuse good
popscat is offline
post #2 of 3 (permalink) Old 06-26-2005, 02:42 AM
benzboyz's Avatar
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
RE: horn
try to check if there is voltage going to the horn itself, use a voltmeter, voltage should be 11-12v, if you do not have a voltmeter try using a test lamp. the two terminals on the back of the horn is the one you should test, have another person push the horn button, if the voltage ot the lamp lights up the problem is your horn, you might have to replace both. there are no relays for this 124 version only a direct battery voltage to the horn and ground for this is supplied from the horn button, you can also check the horn button maybe the contacts are oxidized. or try cleaning the brush contacts in the steering wheels.
benzboyz is offline
post #3 of 3 (permalink) Old 07-11-2005, 02:08 AM
Storm's Avatar
Date registered: Jan 2004
RE: horn
The horn(s) in my E280 (W210) wasn't working I found the horn itself to be the culprit (water damage).
Storm is offline
