How do I replace the Air Filter in my S430 or G500?? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-23-2005, 02:50 PM Thread Starter
Man-Du-Ru-Gas's Avatar
Date registered: Nov 2002
Vehicle: 04 G500
Does anyone know the proceedure or a DIY??
04' G500 (G-Wagen) Benz (sold) <== we trully miss her.
04' Range Rover <== Traded with an Audemars Piguet RG Royal Oak Montoya =)
07' BMW 750Li <== traded this in, economy is down.
10' Acura TL w/ Tech package. (I'm loving this new ride)
09' GL320 BlueTec Black on Black w/ Everything except the grille guard.
08' Gallardo Spyder on HRE's
Man-Du-Ru-Gas is offline
post #2 of 6 (permalink) Old 06-26-2005, 01:37 AM
Date registered: Jun 2004
Vehicle: 1978 450SE
Send a message via AIM to RoxyBlonde451
RE: How do I replace the Air Filter in my S430 or G500??
They are in the plastic engine cover. Remove the 2 air inlet hoses carfully from the front, and gently pull up the whole housing. It's pushed on in the front, and there are two on the sides (and the attached rubber ring around the mass air). You gently pull up on the front piece, but leave it attached to the rest of the housing (it can come off seperatly, but that's where most people break it). Then pull straight up from the two sides. Cover the mass airflow sensor in the back with a rag to ensure no dust gets into it. (It's that round thing with the electrical connector at the center back of the motor) Flip over the case onto a workspace, and depending on the model, unclip the holding clips to release the filter covers, and/or use the T20 torx driver, and unscrew all the screws. Remove the filters, and blow off the inside to get the residual dirt, and whatnot out, then just replace with new filters, and reverse the removal process for installation.
Don't forget to uncover the mass air sensor before putting the housing back on, and ensure that the rubber ring on the housing is properly secured back around the mass air sensor, it should slip around it snugly, or you might have drivability issues.
RoxyBlonde451 is offline
post #3 of 6 (permalink) Old 06-26-2005, 03:49 AM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
very easy just remove both plastic pipes of the air intake, then hold the air filter housing either sides and lift it up, aircleaner asembly is just clip to the engine, to remove the filter you need a star screw driver, there are 8 screws all in all.
both your g class and s class has the same filter housing.
hpe this will solve your problem pare!
benzboyz is offline
post #4 of 6 (permalink) Old 06-26-2005, 07:16 PM Thread Starter
Vehicle: 04 G500
Thanks for the detailed instructions. I knew someone in benz world has replaced their air filter.
post #5 of 6 (permalink) Old 06-26-2005, 11:55 PM
Vehicle: 1978 450SE
Man-Du-Ru-Gas - 6/26/2005 6:16 PM
Hahaha, kinda. I'm a tech at a dealership.
The air filter on my benz is easier to figure out on your own. It's old.
post #6 of 6 (permalink) Old 12-26-2008, 10:57 AM
Date registered: Dec 2008
Vehicle: 2003 S430 4-matic, charcoal on black
great just what i was looking for..thanks to all the answears.
sclassbenz is offline
