W202 AC System??? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-18-2005, 11:53 AM Thread Starter
Date registered: Jun 2005
Send a message via MSN to ivanpierce Send a message via Yahoo to ivanpierce
W202 AC System???
Does anyone know how to get better performance out of my ac system. Over the last two years it has been totally replaced with OEM products. I can get into almost any other car and the force of air leaving the vents is very strong...but in my car it seems weak. I have found this in almost every other mercedes...is there anything that I can do to get more force, higher air speed and stronger air movement???? Thanks.
ivanpierce is offline
post #2 of 3 (permalink) Old 06-25-2005, 03:41 AM
benzboyz's Avatar
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
RE: W202 AC System???
what you can try to check is wheather the vacuum line connected to the engine side is in order, otherwise try to replace the air intake filter of the a/c system and the charcoal filter if fitted with this. you can also check the blower condition, when you switch the blower to max. you will really hear a big noise from it, if not maybe the blower doesn't work well
benzboyz is offline
post #3 of 3 (permalink) Old 06-26-2005, 12:25 AM
Date registered: Jun 2004
Vehicle: 1978 450SE
Send a message via AIM to RoxyBlonde451
There has been a number of problems with the blower motors on those cars (and the W210). Usually the regulator starts to go. That is replaceable without having to replace the entire motor assemb.. After checking vacuum lines for cracks, and leaks, and the charcoal filter, that's where I would go next.
RoxyBlonde451 is offline
