water in transmission - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-15-2005, 01:53 AM Thread Starter
Date registered: May 2005
Hi guys,
Whats the best way to flush an automatic gearbox thats had plenty of water in it, without having to pull it apart.
paintarola is offline
post #2 of 3 (permalink) Old 06-15-2005, 01:21 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 9 Post(s)
RE: water in transmission
Drop the pan. If it ran at all ( and isn't toast ) you'll need to drain the torque converter and replace the filter too.
Have a fresh gasket handy.
Mike
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline
post #3 of 3 (permalink) Old 06-25-2005, 04:54 AM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
Normally you can have the oil replace the oil by draining the oil on the torque converter and the oil pan drain plugs, but the oil on the cooler is still old. its alittle complicated but it can be done. some do this by removing the screw on the leftside of the coller hose and start the engine the oil which is on the cooler will be flushed out and when you see the oil comming out which is cleaner you can shut-off the engine and replace the scres back. abd don't forget to correct the oil level
benzboyz is offline
