2003 500sl coolant leak - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-14-2005, 12:18 PM Thread Starter
Date registered: Jun 2005
I have a 2003 500 SL with a hard to find coolant leak. It appears to be coming from the area around the coolant tank. It shows up on the ledge of the inner fender well. But I can't tell where it is coming from. Can any body help?
Thanks
autonj@aol.com is offline
post #2 of 3 (permalink) Old 06-14-2005, 06:28 PM
Vehicle: 2005 E320 cdi
RE: 2003 500sl coolant leak
My suggestion-purchase a coolant system pressure tester if you are a diy'er or have someone at a shop that you trust put a pressure test on the coolant system to find your leak. I've been in the used car business for 15 years as a hobby and have had coolant leaks drive me nuts over the years.Coolant has a tendancy to drip and flow in places that you would suspect a leak, but the leak originates from another location. The pressure test simulates operating conditions while the engine is not running and gives you a clear depection of the origin of the leak.
Hope this helps!
junkman is offline
post #3 of 3 (permalink) Old 06-14-2005, 06:50 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, autonj. Junkman's giving you good advice, if you have an Autozone around they loan tools for free (basically you "buy" the tool and have 90 days to return it and they refund all your money).
Good luck! Hope it is 1) easy to find and 2) simple and cheap to fix!!
Greg
Check Codes is offline
