viscous fan on sel - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 06-08-2005, 10:55 AM Thread Starter
Date registered: Jun 2005
viscous fan on sel
my 380 sel consistantly overheats. i am told the vicous fan clutch is naff any comments
dackdyde is offline
post #2 of 14 (permalink) Old 06-08-2005, 02:50 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: viscous fan on sel
I assume ‘naf’ is bad.
If the clutch is not engaging, replace it.
Check also the aux fan, coolant level, water pump, and t stat. A cooling system flush and refill may be needed. Post in the 126 forum.
jdc1244 is offline
post #3 of 14 (permalink) Old 01-13-2006, 07:03 PM
verdejor's Avatar
Date registered: Aug 2005
Vehicle: 1976 W116, 450SE --- 1981 W126, 380 SEL--- 1972 W108, 280SEL---1963 W111, 200S
does the fan turn on before/during it overheats?
if not, check the cooling fan sensor. Replace if fan runs all the time also.
check proper coolant to water ratio was correct.
is the car idling too fast? check your rpm/timing also... this messes with it too.
It's not all that, But it's mine.
http://www.cardomain.com/id/verdejor
verdejor is offline
post #4 of 14 (permalink) Old 01-14-2006, 05:27 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
In the future, you probably will get more responses if you post in the forum specific for your model i.e. the w126 forum.
Mike
Mike
Michael Pillay is offline
post #5 of 14 (permalink) Old 01-14-2006, 05:38 AM
~BANNED~
deathrattle's Avatar
Date registered: Jan 2005
Vehicle: 1992 W126 300 SE
Quoted: 2 Post(s)
jdc
"I assume ‘naf’ is bad".
naff= bad, drab (from Not Available For Fucking).Part of the 'Polari' slang adopted and developed by the London gay community of the 50s and 60s.
deathrattle is offline
post #6 of 14 (permalink) Old 01-14-2006, 05:42 AM
~BANNED~
Quoted: 2 Post(s)
Verdejor
"check proper coolant to water ratio was correct".
Why?-What has that to do with overheating??
post #7 of 14 (permalink) Old 01-14-2006, 06:06 AM
am3037's Avatar
Date registered: Dec 2004
Vehicle: Perlmuttgrau 300SEL
Send a message via MSN to am3037
you say overheating? does teh needle actually go into the red, or does it just hover around the 100 degree mark alot?
Cheers,
Aaron
Pearl Grey 300SEL.
HK import, 103,000miles.
am3037 is offline
post #8 of 14 (permalink) Old 01-14-2006, 07:48 AM
jdc1244's Avatar
deathrattle - 1/14/2006 7:38 AM
jdc
Thanks DR for the definition, I’ve been wondering about that for more than six months now…
jdc1244 is offline
post #9 of 14 (permalink) Old 01-14-2006, 08:01 AM
~BANNED~
Quoted: 2 Post(s)
jdc1244a - 1/14/2006 2:48 PM
jdc
Yes,in fact I only happened upon the origin recently.I was quite surprised actually,for some reason I always assumed it was an old army expression.
Incidently,think twice before you call someone a 'berk'!
Sorry for veering off topic guys[:)]
post #10 of 14 (permalink) Old 01-14-2006, 08:10 AM
jdc1244's Avatar
deathrattle - 1/14/2006 10:01 AM
I don’t think it matters in a thread this old where the author is more than likely no longer with us.
jdc1244 is offline
