a/c question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-07-2005, 07:34 PM Thread Starter
Date registered: Oct 2002
a/c question
My old reliable 1986 l90e air conditioner seems to have gotten a mind of its own. Unit is fully charged, compresser is not frozen, yet unit does not always go on when the ac button is hit. Sometimes it does sometimes not.
Could it be the relay (can you test this part?) What else could it be.
Is there a way to test if the compressor electromagent is getting l2 volts. Ie can I test to see if unit is getting power. There is a two wire electrical connection goeing to compressor. What are the two wires?
Any help appreciated.
tmryan is offline
post #2 of 3 (permalink) Old 06-07-2005, 07:47 PM
Date registered: Jun 2005
RE: a/c question
I am new to MB, but I've worked on VW's & BMW's and they are all a lot a like in technology.
check to see if the unit has a high/low pressure switch, it's usually mounted on the condensor I believe. It controls the a/c cycling on/off based on system pressure.
f5000sl is offline
post #3 of 3 (permalink) Old 06-07-2005, 09:42 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 8 Post(s)
RE: a/c question
Had a similar problem a few years ago.
Turned out to be the control unit assembly -- which is the assembly of relays and switches behind the panel on the cluster.
Good luck.
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline
