1990 300E water pump replacement - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-04-2005, 07:48 PM Thread Starter
Date registered: Jun 2005
Vehicle: 300E
Send a message via AIM to leopacana Send a message via MSN to leopacana Send a message via Yahoo to leopacana
does anyone have ANY tips on replacing this H2O pump? what exactly has to come off and/or be loosened before i can access THEE pump
leopacana is offline
post #2 of 2 (permalink) Old 06-07-2005, 09:52 PM
mjhawkins2346's Avatar
Date registered: Nov 2002
Vehicle: 10 GLK 350 4Matic
Quoted: 8 Post(s)
RE: 1990 300E water pump replacement
More details might be useful. Are you experienced with this type of repair?
In general, it is not a difficult job with the right tools.
General Directions;
- Remove radiator hoses - capture old coolant
- Remove trans cooler lines and plug with stopper
- Pull shroud, pull radiator
- Remove clutch fan assembly
- Loosen belt
- Remove pump assembly. You may have an impeller
assembly you can pull from the center of the pump
housing and avoid a complete pump replacement
- Reverse steps
Good luck
Now: 2010 GLK350 4Matic Then: 2003 C320 4Matic, 2006 E320 CDI, 2000 E320, 1994 E320, 1991 190E, 1985 300D, 1983 300D
"Eagles may soar, but weasels don't get sucked into jet engines."
mjhawkins2346 is offline
